question about installing Openfoam 1.6-ext
Old   November 10, 2013, 20:25
Default question about installing Openfoam 1.6-ext
Haotian
Haotian is on a distinguished road
Hello, guys
I'm planning install Openfoam 1.6-ext on my computer windows 7. I installed VMplayer and Ubuntu 12.04 (i386). But when I Allmake.stage3 in third party, it give me the errors.
Package name      : libccmio-2.6.1
Package URL       : http://portal.nersc.gov/svn/visit/ta...o-2.6.1.tar.gz
RPM spec file name: libccmio-2.6.1.spec
Additional flags  :
Updating the ThirdParty environment variables before building package libccmio-2.6.1
Making package libccmio-2.6.1 using RPM.
Building package libccmio-2.6.1 using SPEC file : libccmio-2.6.1.spec. Optional args:
Executing(%prep): /bin/sh -e /home/wanghaotian0822/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.KEBvWP
+ umask 022
+ cd /home/wanghaotian0822/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD
+ rm -rf libccmio-2.6.1
+ /bin/tar -xf -
+ /bin/gzip -dc /home/wanghaotian0822/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/SOURCES/libccmio-2.6.1.tar.gz
+ STATUS=0
+ [ 0 -ne 0 ]
+ cd libccmio-2.6.1
+ echo Patch #0 (libccmio-2.6.1.patch_0):
+ /usr/bin/patch -s -p1 --fuzz=0
+ /bin/cat /home/wanghaotian0822/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/SOURCES/libccmio-2.6.1.patch_0
+ exit 0
Executing(%build): /bin/sh -e /home/wanghaotian0822/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.hwg61Q
+ umask 022
+ cd libccmio-2.6.1
+ [ -n gcc ]
+ export CC=gcc
+ [ -n g++ ]
+ export CXX=g++
+ [ -n  ]
+ [ -n  ]
+ [ -n  ]
+ [ -z 4 ]
+ unset RELEASE
+ unset DEBUG
+ unset STATIC
+ unset SHARED
+ [ -d libadf ]
+ cd libadf
+ RELEASE=1 SHARED=1 make -f Makefile.qmake all
..//config/runqmake ../ \
      -o Makefile.adf adf.pro 2>&1 | tee qmake.vars
..//config/runqmake: line 47: /home/wanghaotian0822/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/libccmio-2.6.1/libadf/..//config/unknown/qmake: No such file or directory
make[1]: Entering directory `/home/wanghaotian0822/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/libccmio-2.6.1/libadf'
make[1]: *** No rule to make target `/u/xeona04/people/prewett/src/libccmio/config/linux64_2.4-x86-glibc_2.2.5/qmake.conf', needed by `Makefile.adf'.  Stop.
make[1]: Leaving directory `/home/wanghaotian0822/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/libccmio-2.6.1/libadf'
make: *** [all] Error 2
error: Bad exit status from /home/wanghaotian0822/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.hwg61Q (%build)
RPM build errors:
Installing package: libccmio-2.6.1
  Uninstalling libccmio-2.6.1 using RPM: libccmio-2.6.1-linuxGcc46DPOpt.i386
  Installing libccmio-2.6.1 using RPM file: /home/wanghaotian0822/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/i386/libccmio-2.6.1-linuxGcc46DPOpt.i386.rpm
error: open of /home/wanghaotian0822/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/i386/libccmio-2.6.1-linuxGcc46DPOpt.i386.rpm failed: No such file or directory
Done installing package
Do you have any ideas about that?
Thank you.
Haotian is offline   Reply With Quote
Old   November 15, 2013, 15:59
Retired Super Moderator
Bruno Santos
Greetings Haotian,
The error indicates that qmake is missing. If I'm not mistaken, you can install it by running:
sudo apt-get install libqt4-dev
By the way, which installation instructions are you following?
Best regards,
Bruno
Old   November 17, 2013, 18:47
Haotian
Thank you Bruno. I just update the Ubuntu to 12.04 x86, and it works for the openfoam 1.6-ext.
Haotian
Test directory missing in OpenFOAM 1.6 ext andrewryan OpenFOAM 2 March 20, 2011 15:41
Compatibility OpenFOAM 1.6 and 1.7.1 Ale_galleria OpenFOAM 2 September 20, 2010 09:14
OpenFOAM 1.6 package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 36 September 2, 2009 12:46
Problem on Installing OpenFOAM 1.6 on Fedora 11 lzgwhy OpenFOAM Installation 1 August 25, 2009 11:02
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
