Double Slash bug during BuildingProc.
Old   February 21, 2014, 10:01
Default Double Slash bug during BuildingProc.
MangoMango is on a distinguished road
actually I'm trying to build&install OpenFOAM 2.3.0 on a cluster. During the building processes the making script is using "//" behind the defined foamInstall path in the pathcommands to includefiles and libraryfiles (e.g.: -I/mypath//OpenFOAM...InInclude). I changed it to foamInstall=/mypath/$WM_PROJECT ...
Software on the system:
gcc4.7.3
kernel2.6.32-5-amd64 (debian squeezy)
make 3.81
Even if I use the preset-settings this error occurs.
I really don't know what I've to do...so I would be really glad if someone could give me a hint.
Kind Regards
Alex
MangoMango is offline   Reply With Quote
Old   February 21, 2014, 11:13
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
I guess between these two slashes environment variable should be (and as it is not set it is expanded to empty string and you've got two slashes). You've provided not enough information for more suggestions.
alexeym is offline   Reply With Quote
Old   February 21, 2014, 11:39
Hi Alexey,
thank you very much for your answer. Indeed, it is difficult to describe this problem, because I'm new to the cluster.
I followed to this proccedings http://levlafayette.com/node/357 .
The only changes I made are
foamInstall=/hera/fmt/alex/src/$WM_PROJECT
and
WM_MPLIB=SYSTEMOPENMPI
Despite of the double slash the dependency making process seems to be normal. e.g.: -I/hera/fmt/alex/src//OpenFOAM-2.3.0/src/OSspecific/POSIX/lnIncude
Hopefully this information will help you to guess the problem. Otherwise please tell me which information do you need?
Thank you so far
Best regards,
Alex
Old   March 1, 2014, 19:23
Retired Super Moderator
Bruno Santos
Greetings to all!
@Alex: The big question is, where exactly did you define this line :
Because it should have been defined in line #45, namely here: https://github.com/OpenFOAM/OpenFOAM...etc/bashrc#L45
If not, then it's the same as this:
which would explain why you got the double slashes.
Best regards,
Bruno
Old   March 3, 2014, 04:52
Hi Bruno,
thank you very much. I changed the line in the etc/bashrc script. The error disappeared after a rebuild from scratch. With a newer gcc version.
Up to now it seems to work fine.
Best regards,
Alex
@all thank you for all your suggestions
bug, building, openfoam
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 03:34
New densitybased solver AeroFoam giulio_romanelli OpenFOAM Running, Solving & CFD 48 January 15, 2016 08:20
Parallel User Defined Real Gas Model aeroman FLUENT 4 July 1, 2015 06:09
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
