OpenFOAM 2.3.0 + HELYX-OS - ld.so error.
Like Tree2Likes
  • 2 Post By astrohome
Old   July 27, 2014, 14:17
Default OpenFOAM 2.3.0 + HELYX-OS - ld.so error.
Illia Izotov
astrohome is on a distinguished road
I have a big problem with my current installation.
My system is Linux Mint 17 (so, basically Ubuntu 14.04). I installed OpenFOAM 2.3.0 from sources according to guide http://openfoamwiki.net/index.php/In...M-2.3.0/Ubuntu
I launched some tutorial (rhoSimplecFoam) and I see no problems - blockMesh, than rhoSimplecFoam and paraFoam works without any problem.
After that, I installed HELYX-OS GUI (without kernel) and tried to do some basic meshing. I set OpenFOAM installation dir and it started meshing but it stops in a second with this error:
*    Run Mesh    *
Case         : /home/felix/OpenFOAM/projects/test/test
Procs        : 4
Log          : /home/felix/OpenFOAM/projects/test/test/log/snappyHexMesh.log
Env          : /home/felix/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc
Vendor       : /home/felix/OpenFOAM
MachineFile  :
Solver       :
Inconsistency detected by ld.so: dl-version.c: 224: _dl_check_map_versions: Assertion `needed != ((void *)0)' failed!
My .bashrc file:
source /home/felix/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc
Diagnostic output:
felix@Astrolap ~/OpenFOAM/OpenFOAM-2.3.0/bin $ ./foamInstallationTest
Executing ./foamInstallationTest:
Checking basic setup...
Shell:              bash
Host:               Astrolap
OS:                 Linux version 3.16.0-031600rc6-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory                Valid      Crit
$WM_PROJECT_INST_DIR /home/felix/OpenFOAM                     yes       yes
$WM_PROJECT_USER_DIR /home/felix/OpenFOAM/felix-2.3.0         no        no
$WM_THIRD_PARTY_DIR  /home/felix/OpenFOAM/ThirdParty-2.3.0    yes       yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory                Valid Path Crit
$WM_PROJECT_DIR      /home/felix/OpenFOAM/OpenFOAM-2.3.0      yes  yes  yes
$FOAM_APPBIN         ...-2.3.0/platforms/linux64GccDPOpt/bin  yes  yes  yes
$FOAM_SITE_APPBIN    .../2.3.0/platforms/linux64GccDPOpt/bin  no        no
$FOAM_USER_APPBIN    ...-2.3.0/platforms/linux64GccDPOpt/bin  no        no
$WM_DIR              .../felix/OpenFOAM/OpenFOAM-2.3.0/wmake  yes  yes  yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN         ...-2.3.0/platforms/linux64GccDPOpt/lib  yes  yes  yes
$FOAM_SITE_LIBBIN    .../2.3.0/platforms/linux64GccDPOpt/lib  no        no
$FOAM_USER_LIBBIN    ...-2.3.0/platforms/linux64GccDPOpt/lib  no        no
$MPI_ARCH_PATH       ...0/platforms/linux64Gcc/openmpi-1.6.5  no        yes
Third party software
Software Version   Location
flex     2.5.35    /usr/bin/flex
gcc      4.8.2     /usr/bin/gcc
gzip     1.6       /bin/gzip
tar      1.27.1    /bin/tar
icoFoam            ...M/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/icoFoam
Summary
Base configuration ok.
Critical systems ok.
Done
Please help, I've spent already a weekend for this initial config and still have nothing
astrohome is offline   Reply With Quote
Old   July 27, 2014, 15:58
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Try this one out.
http://www.cfd-online.com/Forums/ope...u-14-04-a.html
This may work for you. I have yet to test HELYX-OS on Ubuntu 14.04 as I was waiting a few months to make the leap to the next LTS version.
chegdan is offline   Reply With Quote
Old   July 27, 2014, 16:13
Illia Izotov
Originally Posted by chegdan View Post
Try this one out.
Thanks a lot! Actually, I saw that solution and even tried some methods, but it seems one should recompile OpenFOAM using new .bashrc file. Thanks again, you saved my weekend!!
EDIT: I found another thread, http://www.cfd-online.com/Forums/ope...pyhexmesh.html and the very last post works like a charm:
I add the lines:
source $HOME/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc
alias of230='source $HOME/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc WM_NCOMPPROCS=2 WM_MPLIB=SYSTEMOPENMPI'
to my $HOME/.bashrc and compiling OpenFOAM with Allwmake.
chegdan and roozbehmousavi like this.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 09:40
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
