OpenFOAM 2.3.0 on Ubuntu 12.04 - "paraview: not found"
Old   November 2, 2014, 07:20
Default OpenFOAM 2.3.0 on Ubuntu 12.04 - "paraview: not found"
Yongxiao Wang
Yanci is on a distinguished road
Hi there,
I am new to OpenFoam.I've installed OpenFOAM 2.3.0 on Ubuntu 12.04 .
I'm having issues when I try to run the paraFoam.
code:
[>blockMesh >icoFoam >paraFoam]
I receive the following for paraFoam:
created temporary 'cavity.OpenFOAM'
/opt/openfoam230/bin/paraFoam: 265: /opt/openfoam230/bin/paraFoam: paraview: not found
What should I do ?
Please help me !!
Yanci is offline   Reply With Quote
Old   November 2, 2014, 07:54
Retired Super Moderator
Bruno Santos
Quick answer - It seems you skipped an important installation step: http://www.openfoam.org/download/ubuntu.php
4. Install Paraview (410 in the name refers to version 4.1.0):
sudo apt-get install paraviewopenfoam410
After that, run again:
source /opt/openfoam230/etc/bashrc
Old   November 2, 2014, 19:31
Yongxiao Wang
Hello Bruno ,
Thank you for your help. It worked, now paraview works just fine !
In fact, before that, another question about paraFoam was settled depending on your replying in other post.http://www.cfd-online.com/Forums/ope...-parafoam.html
Thank you once again!
BEST REGARDS,
Yongxiao Wang
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 15:11
Prolem installing OpenFOAM Ver 2.3.0 source in Ubuntu 13.1.0 on VMware zandi OpenFOAM Installation 5 March 31, 2014 03:57
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 11:37
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
