[OpenFOAM.org] Trying to build and install OpenFOAM 2.4.0 on Lubuntu 14.04 ARM7
Like Tree8Likes
Old   June 26, 2015, 16:58
Default Trying to build and install OpenFOAM 2.4.0 on Lubuntu 14.04 ARM7
Tanneru Hemanth Kumar
Hemanth is on a distinguished road
Checking basic setup...
Shell:              bash
Host:               netbook
OS:                 Linux version 3.4.5
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory                Valid      Crit
$WM_PROJECT_INST_DIR /home/student/OpenFOAM                   yes       yes
$WM_PROJECT_USER_DIR /home/student/OpenFOAM/student-2.4.0     yes       no
$WM_THIRD_PARTY_DIR  /home/student/OpenFOAM/ThirdParty-2.4.0  yes       yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory                Valid Path Crit
$WM_PROJECT_DIR      /home/student/OpenFOAM/OpenFOAM-2.4.0    yes  yes  yes
$FOAM_APPBIN         ....4.0/platforms/linuxARM7GccDPOpt/bin  no        yes
$FOAM_SITE_APPBIN    ....4.0/platforms/linuxARM7GccDPOpt/bin  no        no
$FOAM_USER_APPBIN    ....4.0/platforms/linuxARM7GccDPOpt/bin  no        no
$WM_DIR              ...tudent/OpenFOAM/OpenFOAM-2.4.0/wmake  yes  yes  yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN         ....4.0/platforms/linuxARM7GccDPOpt/lib  no        yes
$FOAM_SITE_LIBBIN    ....4.0/platforms/linuxARM7GccDPOpt/lib  no        no
$FOAM_USER_LIBBIN    ....4.0/platforms/linuxARM7GccDPOpt/lib  no        no
$MPI_ARCH_PATH       /usr/lib/openmpi                         yes  yes  yes
Third party software
Software Version   Location
flex     2.5.35    /usr/bin/flex
gcc      4.8.4     /usr/bin/gcc
g++      4.8.4     /usr/bin/g++
gzip     1.6       /bin/gzip
tar      1.27.1    /bin/tar
icoFoam
WARNING:  Conflicting installations:
          OpenFOAM settings        : /home/student/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxARM7GccDPOpt/bin/icoFoam
          current path             :
          CRITICAL ERROR
Summary
Base configuration ok.
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for troubleshooting.
Done
Please help in solving this.
Last edited by wyldckat; June 28, 2015 at 16:00. Reason: Added [CODE][/CODE] markers
Hemanth is offline   Reply With Quote
Old   June 27, 2015, 14:03
Default Problem in open foam installation through ubuntu deb method
Followed installation instructions . got the following erros after sudo apt-get install
failed to faetch http://www.openfoam.org/download/ubuntu/dists trusty/main/binary-armfh/Packages 404 Not Found
uname - m gives
armv7l
Please help .
Old   June 28, 2015, 16:06
Retired Super Moderator
Bruno Santos
Greetings Hemanth and welcome to the forum!
I'm sorry to say that the OpenFOAM 2.4.0 Deb packages are not available for the ARM architectures.
The closest I know about people being able to build/install OpenFOAM on ARM7 architectures have been these two:
Best regards,
Bruno
Last edited by wyldckat; July 19, 2015 at 13:09. Reason: added a 3rd and a 4th link to the list - repaired 4th
Old   June 29, 2015, 02:11
Thanks Bruno for the reply. Glad to know at least there are two people who installed openfoam on armv processer.
I have goen through the first link and the conversation. I didn't clearly understand all the instructions.
I am not knowing where to start and what to do.
Pelase help me with the procedure to modify the things as per Jon Elvar Wallevik suggested.
Any ways i will try doing some thing and mean while, i tried installation from source pack I got some error for which i am attachng the log file. Please help me with this if this problem is easy to fix.
Old   July 5, 2015, 15:12
Bruno Santos
Quick answer:
  1. Run these commands:
    gcc --version
    g++ --version
    and let me know what each command gives you.
  2. Then run these commands:
    foam
    ./Allwmake > log.make 2>&1
    gzip < log.make > log.make.gz
    And attach the file "log.make.gz" in your next post.
Old   July 6, 2015, 01:32
gcc --version gives
gcc (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04) 4.8.4
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
g++ --version gives
g++ (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04) 4.8.4
Here is log file. It shows the directory is not available because i deleted OpenFOAM folder. If you want me to compile again i will do that. Can you please send detailed instructions if available to install openfoam in ARM architecture.
Thanks in advance and in the rhelogical site i didnt understand which version to download and how to install.
Please help.
File Type: gz log.make.gz (64 Bytes, 2 views)
Old   July 19, 2015, 13:24
Bruno Santos
Hi Hemanth,
Sorry for the late reply, but only today did I finally manage to take a quick look into this.
If you're trying to install OpenFOAM 2.4.0 on a RaspberryPi 2, then you might want to check this post: http://www.cfd-online.com/Forums/ope...tml#post556013 - post #5
If you have some other machine, then the best I can suggest is as follows:
  1. Follow the instructions given here: http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04
  2. But when you reach step #6, use the option for "i686", which should also work with "armvl7".
  3. These instructions do provide the indication of what needs to be done for diagnosing problems with building OpenFOAM.
Beyond this, I have no idea what else is needed.
Best regards,
Bruno
Old   July 19, 2015, 13:34
Thanks Bruno,
Will try and let you the progress next weekend. How to whether system is rasberry pi or not ?
Old   July 19, 2015, 13:43
Bruno Santos
If you're able to look at the machine itself (the tower or box for the computer), then it's a Raspberry Pi if the contents of the box looks something like the images shown here: https://en.wikipedia.org/wiki/Raspberry_Pi - there is also a table there listing the physical dimensions of each version.
Old   July 19, 2015, 14:42
Default Raspberry Pi
daniel
leinad is on a distinguished road
I have recently build a Raspberry Pi cluster, using Raspberry pi model b 2, i have Openfoam 2.4.0 running every thing works, I can put together a how to if any one is intrested
wyldckat and Hemanth like this.
leinad is offline   Reply With Quote
Old   July 19, 2015, 23:13
Hi Linead,
Can you post a step by step post for installing Openfoam2.4 on ARM architecture if possible.
Old   July 20, 2015, 02:59
daniel
Hi Hemanth
Yes that's not a problem I will put together a pdf as there are a few people who are interested. Depends how my workload is at work but hopefully I will get some thing on here within the next few days
Old   July 20, 2015, 16:05
Default OpenFoam For Raspberry Pi
  #13
daniel
To Hemanth and every one else that is looking to install OpenFoam on a Raspberry Pi, see attachment.
I hope it is useful to some one, if you like this tutorial and you have any knowledge of setting up a axial fan boundary condition please let me know as that is what i need help with
7islands, Taataa, mvbakker and 1 others like this.
Old   July 21, 2015, 02:52
Originally Posted by wyldckat View Post
Hi Hemanth,
Best regards,
Bruno
I followed the procedures and here is the zip file of make.log .
Can you help from this if you can ?
Old   July 21, 2015, 03:00
daniel
Hemanth
Try the instructions in the pdf I posted yesterday
Old   July 21, 2015, 07:17
Hi Daniel,
When i did ./Allwmake in the path sepecified in instructions, It throws an error .
./Allwmake: 4 : ./Allwmake: wmake chkPwd : not found
Error : Current directory is not $WM_PROJECT_DIR
The environment variables are inconsistent with the installation.
Check the Open FOAM entries in your dot-files and source them.
It might be because of the previous environment variables that are set during installation through the other method by Bruno.
Old   July 21, 2015, 08:35
daniel
Hi Hemanth
What os are you using ?
I would suggest you start with reinstalling your os so that every thing is default then try again
Old   November 2, 2015, 15:22
Michiel Bakker
mvbakker is on a distinguished road
I just followed your tutorial. I only did not take the latest version of Rasbian but I took the one from May (Wheezy) since I assumed you used that one as well (Rasbian Jessie wasn't out when you guys had this discussion).
Unfortunately I got the exact same error as Hemanth. What should I do? Try it with Rasbian Jessie?
Did you succeed eventually Hemanth?
mvbakker is offline   Reply With Quote
Old   November 2, 2015, 16:01
daniel
Strange that both of you are having troubbles. As two people have had the same error I will review the tutorial to make sure there are no errors and I will update. I am currently at the open foam user event and don't have the cluster to hand but I should get back to you by the end of the week
mvbakker likes this.
Old   November 5, 2015, 06:58
Michiel Bakker
I am not sure yet but I might have fixed it by running:
source /home/pi/OpenFOAM/OpenFOAM-2.4.0/etc/bashrc
which loaded the environment variables (I guess, I'm also new to this). Now it is doing stuff after I ran:
/.Allwmake
Does this seem like a logical solution?
SU2 Parallel Build Install Issue jclegg SU2 4 October 20, 2020 04:28
[OpenFOAM.org] Build and install OpenFOAM Dev 64 bits echin OpenFOAM Installation 8 June 24, 2016 03:54
Install openFOAM from with proxy server Dhruval OpenFOAM Installation 3 October 18, 2014 15:38
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
