[OpenFOAM.org] Installing OpenFOAM 3.0.x on Mac OS X with Homebrew |
December 9, 2015, 11:18 |
#21 | |
Mattia de\' Michieli Vitturi
Rep Power: 17 |
Hi, Unfortunately I have the same problem with libOpenFOAM.dylib. It is in my lib folder but it seems that the solvers do not see it, producing the "dyld: Symbol not found" error. Is there any solution? Thank you Mattia P.S. I am compiling OpeFOAM.3.0.x with latest patch on OSX El Capitan |
December 9, 2015, 11:38 |
#22 |
You need to decide whether you have the same problem: __ZN4FoamlsERNS_7OstreamEl somehow is suppressed from libOpenFOAM.dylib during compilation; or another problem: libOpenFOAM.dylib can not be found. Could you post output of the following commands: Code:
1. sw_vers 2. clang++ --version 3. export | grep -E '(FOAM_|WM_|LD_)' 4. which icoFoam 5. otool -L $(which icoFoam) 6. shasum OpenFOAM-3.0.x-a07401d.patch |
December 9, 2015, 11:48 |
#23 | |
Rep Power: 17 |
1. ProductName: Mac OS X ProductVersion: 10.11.2 BuildVersion: 15C50 2. Apple LLVM version 7.0.2 (clang-700.1.81) Target: x86_64-apple-darwin15.2.0 Thread model: posix 3. declare -x DYLD_LIBRARY_PATH="/usr/local/opt/boost/lib:/usr/local/opt/cgal/lib:/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/lib/openmpi-system:/usr/local/Cellar/open-mpi/1.8.4/lib:/Users/demichie/OpenFOAM/demichie-3.0.x/platforms/darwin64ClangDPInt64Opt/lib:/Users/demichie/OpenFOAM/site/3.0.x/platforms/darwin64ClangDPInt64Opt/lib:/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/lib:/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/lib/dummy:/usr/local/xuggler/lib:/Users/demichie/Dakota/bin:/Users/demichie/Dakota/lib" declare -x FOAM_APP="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/applications" declare -x FOAM_APPBIN="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/bin" declare -x FOAM_ETC="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/etc" declare -x FOAM_INST_DIR="/Users/demichie/OpenFOAM" declare -x FOAM_JOB_DIR="/Users/demichie/OpenFOAM/jobControl" declare -x FOAM_LIBBIN="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/lib" declare -x FOAM_MPI="openmpi-system" declare -x FOAM_RUN="/Users/demichie/OpenFOAM/demichie-3.0.x/run" declare -x FOAM_SETTINGS="" declare -x FOAM_SIGFPE="" declare -x FOAM_SITE_APPBIN="/Users/demichie/OpenFOAM/site/3.0.x/platforms/darwin64ClangDPInt64Opt/bin" declare -x FOAM_SITE_LIBBIN="/Users/demichie/OpenFOAM/site/3.0.x/platforms/darwin64ClangDPInt64Opt/lib" declare -x FOAM_SOLVERS="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/applications/solvers" declare -x FOAM_SRC="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/src" declare -x FOAM_TUTORIALS="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/tutorials" declare -x FOAM_USER_APPBIN="/Users/demichie/OpenFOAM/demichie-3.0.x/platforms/darwin64ClangDPInt64Opt/bin" declare -x FOAM_USER_LIBBIN="/Users/demichie/OpenFOAM/demichie-3.0.x/platforms/darwin64ClangDPInt64Opt/lib" declare -x FOAM_UTILITIES="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/applications/utilities" declare -x LD_LIBRARY_PATH="/usr/local/opt/boost/lib:/usr/local/opt/cgal/lib:/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/lib/openmpi-system:/usr/local/Cellar/open-mpi/1.8.4/lib:/Users/demichie/OpenFOAM/demichie-3.0.x/platforms/darwin64ClangDPInt64Opt/lib:/Users/demichie/OpenFOAM/site/3.0.x/platforms/darwin64ClangDPInt64Opt/lib:/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/lib:/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/lib/dummy" declare -x WM_ARCH="darwin64" declare -x WM_ARCH_OPTION="64" declare -x WM_CC="clang" declare -x WM_COMPILER="Clang" declare -x WM_COMPILER_LIB_ARCH="64" declare -x WM_COMPILE_OPTION="Opt" declare -x WM_CXX="clang++" declare -x WM_DIR="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/wmake" declare -x WM_LABEL_OPTION="Int64" declare -x WM_LABEL_SIZE="64" declare -x WM_LINK_LANGUAGE="c++" declare -x WM_MPLIB="SYSTEMOPENMPI" declare -x WM_OPTIONS="darwin64ClangDPInt64Opt" declare -x WM_OSTYPE="POSIX" declare -x WM_PRECISION_OPTION="DP" declare -x WM_PROJECT="OpenFOAM" declare -x WM_PROJECT_DIR="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x" declare -x WM_PROJECT_INST_DIR="/Users/demichie/OpenFOAM" declare -x WM_PROJECT_USER_DIR="/Users/demichie/OpenFOAM/demichie-3.0.x" declare -x WM_PROJECT_VERSION="3.0.x" 4. /Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/bin/icoFoam 5. /Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/bin/icoFoam: /Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/lib/libfiniteVolume.dylib (compatibility version 0.0.0, current version 0.0.0) /Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/lib/libmeshTools.dylib (compatibility version 0.0.0, current version 0.0.0) /Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/lib/libOpenFOAM.dylib (compatibility version 0.0.0, current version 0.0.0) /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1226.10.1) /usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 120.1.0) 6. da4198af01ad3faa530c7db992a1b524e6003640 OpenFOAM-3.0.x-a07401d.patch Thank you Mattia |
December 9, 2015, 12:18 |
#24 | |
Rep Power: 17 |
This is the error message: dyld: lazy symbol binding failed: Symbol not found: __ZN4FoamlsERNS_7OstreamEl Referenced from: /Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/bin/icoFoam Expected in: flat namespace dyld: Symbol not found: __ZN4FoamlsERNS_7OstreamEl Referenced from: /Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/bin/icoFoam Expected in: flat namespace |
December 9, 2015, 12:25 |
#25 |
I will try to reproduce the error after update (I am using previous version of El Capitan and Xcode CLT).
December 10, 2015, 09:03 |
#26 |
Oleg Kotsur
Rep Power: 13 |
@demichie:
dyld: lazy symbol binding failed: Symbol not found: __ZN4FoamlsERNS_7OstreamEl Referenced from: /Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt64Opt/bin/icoFoam Expected in: flat namespace You can download it from here: http://www.cfd-online.com/Forums/ope...tml#post573097 After this "cheat" I haven't had any problems so far. Last edited by wyldckat; February 7, 2016 at 15:00. Reason: Updated the link |
December 10, 2015, 10:08 |
#27 |
@ demichie:
Unfortunately I was not able to reproduce the error even with updated OS X and Xcode. So could you also post output of 1. xcode-select -p 2. xcrun --show-sdk-path 3. cd $FOAM_LIBBIN && nm libOpenFOAM.dylib | grep __ZN4FoamlsERNS_7OstreamEl && cd - (if you need libOpenFOAM.dylib I could upload it on github, though I would prefer to find the reason for the problem) @o.kotsur: It is not there any more. Also it was for WM_LABEL_SIZE=32. |
December 11, 2015, 04:57 |
#28 |
Rep Power: 17 |
Today I have updated/upgraded everything with brew and now I am trying again to compile. I have noticed this warning during the compilation:
-L/usr/local/opt/libevent/lib -L/usr/local/Cellar/open-mpi/1.10.1/lib -lmpi -o /Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt32Opt/lib/openmpi-system/libPstream.dylib ld: warning: directory not found for option '-L/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt32OptSYSTEMOPENMPI/lib' '/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt32Opt/lib/openmpi-system/libPstream.dylib' is up to date. Do you think this could be related to the problem I have? Thank you Mattia |
December 11, 2015, 07:58 |
#29 |
No, this is not the source of the problem. The reason for the error is this Code:
LINKLIBSO = $(CC) $(c++FLAGS) -Xlinker -dylib \ -Xlinker -flat_namespace \ -Xlinker -undefined \ -Xlinker suppress Currently I am testing another way of linking libraries and applications, as soon as I finish tests, patches on Github will be updated. |
December 11, 2015, 08:00 |
#30 |
Rep Power: 17 |
Thank you Alexey!!
December 14, 2015, 04:08 |
#31 |
@demichie (and maybe @o.kotsur):
I have updated patches, could you test if missing symbol problem has gone? |
December 14, 2015, 04:32 |
#32 |
Rep Power: 17 |
I am compiling it now. I will let you now!
Thanks |
December 14, 2015, 06:19 |
#33 |
Rep Power: 17 |
Compilation failed with the latest patch. I have several errors of this kind:
-lm -o /Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt32Opt/bin/MPPICFoam ld: library not found for -lfiniteVolume clang: error: linker command failed with exit code 1 (use -v to see invocation) make[2]: *** [/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt32Opt/bin/MPPICFoam] Error 1 make[1]: *** [DPMFoam] Error 2 I have attached a .zip of the log |
December 14, 2015, 10:45 |
#34 |
Mea culpa, while implementing "silent rules" removed a little bit more from Makefile, so libraries was not linked with "non-silent rules". Latest commit fixes the problem. You have got rather interesting cpp, is it from gcc package? |
December 15, 2015, 11:26 |
#35 |
Rep Power: 17 |
with the fixed patch the compilation ends but I still have the "dyld: lazy symbol binding failed" problem when running a solver. Regarding cpp, I have tried several version of the gcc package but always without success. Now I am using gcc version 5.3.0 (Homebrew gcc 5.3.0). The latest compilation was with WM_LABEL_SIZE=32. Do you think I can try with your libOpenFOAM.dylib? Thank you Mattia |
December 15, 2015, 15:41 |
#36 |
Right now I do not have build with WM_LABEL_SIZE=32, only 64. I have uploaded archive (https://github.com/mrklein/openfoam-...bs.bins.tar.gz, sha256 is 4538f0fb9af999fe818cf7c20115f8bfd43feac593fe812ce6 f7450c2fd653e0) of bin and lib folders (with stripped library paths, so you won't need to use install_name_tool to correct them) that can be extracted into $WM_PROJECT_DIR (do not forget to backup your original platforms folder just in case, though since it contains non-working build, maybe it is not necessary). To continue diagnostics. Since there is a problem during link phase, could you post output of (since gcc's cpp somehow is in your path, maybe you also try to link with ld from gcc): 1. which ld 2. $(which ld) -v 3. brew list --versions 4. export It seems you have got something installed that prevents normal linking and hopefully output of the commands could shed more light of the problem. |
December 15, 2015, 16:38 |
#37 | |
Rep Power: 17 |
Thank you for your help, I will try with your tar.gz. You can find below the output you requested.
Mattia Quote:
@(#)PROGRAM:ld PROJECT:ld64-253.9 configured to support archs: armv6 armv7 armv7s arm64 i386 x86_64 x86_64h armv6m armv7k armv7m armv7em (tvOS) LTO support using: Apple LLVM 7.0.2 (clang-700.1.81) autoconf 2.69 boost 1.59.0 cgal 4.5 4.6.3 cloog 0.18.1 0.18.4 cmake 3.1.0 3.4.1 fontconfig 2.11.1 freetype 2.5.4 2.6_1 gcc 4.9.2_1 5.3.0 gd 2.1.0_2 2.1.1 gmp 6.0.0a 6.1.0 isl 0.12.2 0.15 jasper 1.900.1 jpeg 8d libevent 2.0.21_1 2.0.22 libgphoto2 2.5.5 2.5.9 libicns 0.8.1_1 libmpc 1.0.2 1.0.3 libpng 1.6.16 1.6.19 libtiff 4.0.3 4.0.6 libtool 2.4.4 2.4.6 libusb 1.0.19 1.0.20 libusb-compat 0.1.5 little-cms2 2.6 2.7 makedepend 1.0.5 metis 5.1.0 metis64 5.1.0 mpfr 3.1.2-p10 3.1.3 open-mpi 1.10.1 1.8.4 openssl 1.0.1j_1 1.0.2e parmetis 4.0.3_3 parmgridgen 0.0.2 pkg-config 0.28 0.29 sane-backends 1.0.24_1 scotch 6.0.0 6.0.4_1 scotch64 6.0.4_1 wine 1.6.2 1.6.2_1 xz 5.0.7 5.2.2 declare -x Apple_PubSub_Socket_Render="/private/tmp/com.apple.launchd.CSZWgr2xdm/Render" declare -x BOOST_ARCH_PATH="/usr/local/opt/boost" declare -x CGAL_ARCH_PATH="/usr/local/opt/cgal" declare -x CLAW="/Users/demichie/Codes/clawpack-4.5.0" declare -x DISPLAY="/private/tmp/com.apple.launchd.YnHXD1E2Ee/org.macosforge.xquartz:0" declare -x DYLD_LIBRARY_PATH="/usr/local/opt/boost/lib:/usr/local/opt/cgal/lib:/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt32Opt/lib/openmpi-system:/usr/local/Cellar/open-mpi/1.10.1/lib:/Users/demichie/OpenFOAM/demichie-3.0.x/platforms/darwin64ClangDPInt32Opt/lib:/Users/demichie/OpenFOAM/site/3.0.x/platforms/darwin64ClangDPInt32Opt/lib:/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt32Opt/lib:/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt32Opt/lib/dummy:/usr/local/xuggler/lib:/Users/demichie/Dakota/bin:/Users/demichie/Dakota/lib" declare -x FC="gfortran" declare -x FOAM_APP="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/applications" declare -x FOAM_APPBIN="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt32Opt/bin" declare -x FOAM_ETC="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/etc" declare -x FOAM_INST_DIR="/Users/demichie/OpenFOAM" declare -x FOAM_JOB_DIR="/Users/demichie/OpenFOAM/jobControl" declare -x FOAM_LIBBIN="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt32Opt/lib" declare -x FOAM_MPI="openmpi-system" declare -x FOAM_RUN="/Users/demichie/OpenFOAM/demichie-3.0.x/run" declare -x FOAM_SETTINGS="" declare -x FOAM_SIGFPE="" declare -x FOAM_SITE_APPBIN="/Users/demichie/OpenFOAM/site/3.0.x/platforms/darwin64ClangDPInt32Opt/bin" declare -x FOAM_SITE_LIBBIN="/Users/demichie/OpenFOAM/site/3.0.x/platforms/darwin64ClangDPInt32Opt/lib" declare -x FOAM_SOLVERS="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/applications/solvers" declare -x FOAM_SRC="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/src" declare -x FOAM_TUTORIALS="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/tutorials" declare -x FOAM_USER_APPBIN="/Users/demichie/OpenFOAM/demichie-3.0.x/platforms/darwin64ClangDPInt32Opt/bin" declare -x FOAM_USER_LIBBIN="/Users/demichie/OpenFOAM/demichie-3.0.x/platforms/darwin64ClangDPInt32Opt/lib" declare -x FOAM_UTILITIES="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/applications/utilities" declare -x GMP_ARCH_PATH="/usr/local/opt/gmp" declare -x HOME="/Users/demichie" declare -x IPYTHONDIR="/Users/demichie/Codes/clawpack-4.5.0/python/ipythondir" declare -x LC_CTYPE="UTF-8" declare -x LOGNAME="demichie" declare -x MANPATH declare -x MATLABPATH="/Users/demichie/Codes/clawpack-4.5.0/matlab" declare -x MPFR_ARCH_PATH="/usr/local/opt/mpfr" declare -x MPI_ARCH_PATH="/usr/local/Cellar/open-mpi/1.10.1" declare -x MPI_BUFFER_SIZE="20000000" declare -x OLDPWD="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x" declare -x PATH="/Users/demichie/OpenFOAM/demichie-3.0.x/platforms/darwin64ClangDPInt32Opt/bin:/Users/demichie/OpenFOAM/site/3.0.x/platforms/darwin64ClangDPInt32Opt/bin:/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt32Opt/bin:/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/bin:/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/wmake:/usr/local/sbin:/Library/Frameworks/Python.framework/Versions/2.7/bin:/opt/local/bin:/opt/local/sbin:/Users/demichie/Dakota/bin:/Users/demichie/Dakota/test:/usr/local/bin:/usr/local/rappture/bin:/opt/local/bin:/opt/local/sbin:/opt/local/bin:/opt/local/sbin:/opt/local/bin:/opt/local/sbin:/opt/local/bin:/opt/local/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/usr/local/git/bin:/usr/texbin" declare -x PWD="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/tutorials/incompressible/icoFoam/cavity" declare -x PYTHONPATH="/Users/demichie/Codes/clawpack-4.5.0/python" declare -x SHELL="/bin/bash" declare -x SHLVL="1" declare -x SSH_AUTH_SOCK="/private/tmp/com.apple.launchd.bm7MDSRglm/Listeners" declare -x TERM="xterm-256color" declare -x TERM_PROGRAM="Apple_Terminal" declare -x TERM_PROGRAM_VERSION="361.1" declare -x TERM_SESSION_ID="8CDE57B0-DC5E-4C01-83FB-28EC1E2AE715" declare -x TMPDIR="/var/folders/b7/x13r82z10fb7ywbys0yzpkwm0000gn/T/" declare -x TRACKER_HOME="/usr/local/tracker" declare -x USER="demichie" declare -x WM_ARCH="darwin64" declare -x WM_ARCH_OPTION="64" declare -x WM_CC="clang" declare -x WM_COMPILER="Clang" declare -x WM_COMPILER_LIB_ARCH="64" declare -x WM_COMPILE_OPTION="Opt" declare -x WM_CXX="clang++" declare -x WM_DIR="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x/wmake" declare -x WM_LABEL_OPTION="Int32" declare -x WM_LABEL_SIZE="32" declare -x WM_LINK_LANGUAGE="c++" declare -x WM_MPLIB="SYSTEMOPENMPI" declare -x WM_NCOMPPROCS="2" declare -x WM_OPTIONS="darwin64ClangDPInt32Opt" declare -x WM_OSTYPE="POSIX" declare -x WM_PRECISION_OPTION="DP" declare -x WM_PROJECT="OpenFOAM" declare -x WM_PROJECT_DIR="/Users/demichie/OpenFOAM/OpenFOAM-3.0.x" declare -x WM_PROJECT_INST_DIR="/Users/demichie/OpenFOAM" declare -x WM_PROJECT_USER_DIR="/Users/demichie/OpenFOAM/demichie-3.0.x" declare -x WM_PROJECT_VERSION="3.0.x" declare -x XPC_FLAGS="0x0" declare -x XPC_SERVICE_NAME="0" declare -x XUGGLE_HOME="/usr/local/xuggler" declare -x __CF_USER_TEXT_ENCODING="0x1F5:0x0:0x0" |
December 16, 2015, 02:19 |
#38 |
This part of your output
/opt/local/bin:/opt/local/sbin:/opt/local/bin:/opt/local/sbin:/opt/local/bin:/opt/local/sbin:/opt/local/bin:/opt/local/sbin Maybe one day (though I doubt it) I will install all the software that is on your laptop (mix Macports and Homebrew, setup fancy PATH, etc) and will be able to reproduce the behavior but not this time. |
December 18, 2015, 21:18 |
#39 |
Pierre-Olivier Dallaire
Rep Power: 17 |
Hi there,
I'm getting the exact same problem here when I try to run icoFoam: dyld: lazy symbol binding failed: Symbol not found: __ZN4FoamlsERNS_7OstreamEl Referenced from: /Volumes/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt32Opt/bin/icoFoam Expected in: flat namespace dyld: Symbol not found: __ZN4FoamlsERNS_7OstreamEl Referenced from: /Volumes/OpenFOAM/OpenFOAM-3.0.x/platforms/darwin64ClangDPInt32Opt/bin/icoFoam Expected in: flat namespace Trace/BPT trap: 5 I'm not using Macport or Brew, I compiled some of the required packages and installed those under /opt. I was able to run snappyHexMesh without a problem but the solvers are failing. Thanks PO update: Using the following worked for me LINKLIBSO = $(cc) -dynamiclib -flat_namespace -undefined suppress LINKEXE = $(cc) -Xlinker -z -Xlinker nodefs Last edited by podallaire; December 18, 2015 at 23:21. Reason: Update |
December 19, 2015, 09:42 |
#40 |
As it is $(cc), seems you have edited wmake/rules/darwin64Clang/c? Or you put this line in wmake/rules/darwin64Clang/c++ (though in this case compilation should fail from the very beginning)? Unfortunately I still can not reproduce the error. On two laptops everything builds and runs smoothly and I still do not have motivation to mess with OS X installation under VirtualBox to reproduce the error. |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
[OpenFOAM.org] Installing OpenFOAM 4.1 on Mac OS Sierra | spitchers | OpenFOAM Installation | 18 | August 11, 2017 10:01 |
[OpenFOAM.org] -bash: fluentMeshToFoam: command not found, after installing OpenFoam 2.3.x on Mac | jundong | OpenFOAM Installation | 1 | July 1, 2015 13:31 |
[swak4Foam] Installing swak4Foam to OpenFOAM in mac | Kaquesang | OpenFOAM Community Contributions | 22 | January 21, 2013 11:51 |
Is it a good idea to use OpenFoam on a Mac (OS 10.7.5) or on Windows7? | bzz77 | OpenFOAM Installation | 4 | November 21, 2012 17:06 |
