[OpenFOAM.com] 3.0+ for Windows - no shell prompt
Like Tree3Likes
  • 2 Post By fisichel
  • 1 Post By fisichel
Old   February 12, 2016, 22:22
Default 3.0+ for Windows - no shell prompt
Chris Fisichella
fisichel is on a distinguished road
I am wondering if anyone has had any success with installing ESI's OpenFOAM for Windows. I got it installed and when I started the OpenFOAM_start program, I got a registry editor error.
Set-ExecutionPolicy : Access to the registry key 'HKEY_LOCAL_MACHINE\SOFTWARE\M icrosoft\PowerShell\1\ShellIds\Microsoft.PowerShel l' is denied.
As it turns out, the advice on this
http://answers.microsoft.com/en-us/w...9b31bf5?auth=1
page is good. I just edited the registry and the error went away.
Now, I get a green "Welcome to the OpenFOAM Windows Version (v3.0+)
A bash shell will appear with OpenFOAM environment set.
I never get a bash shell. Does anyone know how to fix this?
Thanks,
Chris
fisichel is offline   Reply With Quote
Old   February 13, 2016, 21:41
Chris Fisichella
All, there is a PDF in C:\Program Files (x86)\ESI\OpenFOAM\v3.0+\Documents called OF_Windows_Guide.pdf. It provides essential information for installation. For example, I needed to enable hardware virtualization in my BIOS. That, by the way, is found under Security->System for this AMD processor I have.
So far so good. I have a icoFoam -help working. I don't know where the examples are yet, but I have also not finished reading that PDF. At least OpenFOAM is installed.
Thanks for all who viewed.
Old   June 17, 2016, 10:59
Smile
Max Ng
maxkcngcfd is on a distinguished road
Hi Fisichel,
do you mind to share more about how do you edit the register and making the error go away? i tried to read through the link you provide and doesn't get me any where. appreciate your help!
Originally Posted by fisichel View Post
Thanks,
Chris
maxkcngcfd is offline   Reply With Quote
Old   June 17, 2016, 11:41
Default regedit
Chris Fisichella
Sure, You need to use the program regedit. It's part of windows. In that link, it should provide a directory path to go to. Then they have you loosen the permissions.
Does this help? I'm not quite sure where you are stuck,
Best,
Chris
Old   June 17, 2016, 12:10
Max Ng
yes, i managed to get rid of the big red error msg and every thing seem running fine now! thanks Fisichel!
did you go any further from here? i tried to run the tutorial and i manage to get the Icofoam work however i'm having hard time to locate all the boundary condition file, and mesh files etc. the "OF_Windows_Guide.pdf" mentioned that the ‘cd /home/ofuser/workingDir’ is correspond to C:\Users\UserName. but i couldn't find any openfoam related file over there other than bootdocker files and some associated VM files.
without knowing where those case files located i can't change the parameters in the file as well as reading the result with paraview.
Thanks,
Chris
Best,
Chris
Old   June 17, 2016, 13:25
Default Working with the OpenFOAM for Windows shells
Chris Fisichella
Hi Max,
If you have the command window, it has the black screen. Then, you should be able to press the enter key and get a prompt:
The first thing I do is
$cd workingDir
$ls
that listing should correspond to
c:\users\<your login>
You can copy most of the examples that are located at $FOAM_TUTORIALS to this workingDir, then you can use Notepad++ to edit the case directories.
To execute the Allrun script that is every example, you need to be in the shell. A typical job starts like this for me:
$./Allrun <enter>
Then, I use Notepad++ to look at all the log files that are generated.
confused about ./Allrun? Don't try to use icoFoam directly unless you are working with the cavity example that is part of the OpenFOAM users guide.
Best,
Chris
Old   June 17, 2016, 13:56
Max Ng
Hi Chris,
I see! thank you so much! I tried to cp $FOAM_TUTORIALS workingDir. after it throw me some error in the command line, and I saw some files appear in the folder (Finally!!) Do you do it this way too? or what is your recommendation?
did you installed paraview (for window) and get it to work also? yes, i'm trying to going through the cavity tutorial but after i done the icoFoam i do not know what should i do from there inorder to make it display in paraview. sign.
Hi Max,
$cd workingDir
$ls
$./Allrun <enter>
Best,
Chris
Old   June 17, 2016, 14:12
Default Getting started
Chris Fisichella
Hi Max
Try:
$ cp -r $FOAM_TUTORIALS/ ~/workingDir/
If that works, try
$ cd workingDir/tutorials
$ cd incompressible
$ cd icoFOAM
$ cd elbow
$./Allrun
You'll see the cavity examples in the icoFOAM directory. I'm suggesting you go to the elblow example, because all you need to type is ./Allrun.
As for Paraview, I do install Paraview for windows, but it does not work all the time. Of the four machines I have tried it on, it only works on two of them. I hope it works for you, since this is your first time.
Best,
Chris
pgh and maxkcngcfd like this.
Old   June 17, 2016, 14:29
Max Ng
Thanks Chris,
I follow the step that you gave me it throw me the same error too (see the attached picture)
I look it around and found this commend allow me to "export" the file to .foam file
elbow]$ touch filename.foam.
however, i could only manage to display the mesh (model shape) but couldn't display the P and U value.
Old   June 17, 2016, 14:43
Chris Fisichella
That's what I meant when I wrote most of the tutorial can be run in the workingDir.
The case study that is affected is for heat transfer.
Your elbow case should be unaffected.
Did you run ./Allrun in the elbow directory and wait?
Old   June 17, 2016, 15:01
Max Ng
Hi Chris,
yes, i got the elbow case to work also I think i get the paraview to work!!
thanks to Hữu Trọng Lương
https://www.youtube.com/watch?v=LJNyUiDTVjU
so excited now!!
Old   June 17, 2016, 15:20
Chris Fisichella
Great! Have fun!
maxkcngcfd likes this.
[ICEM] .stl file shell to solid part emily.imdieke ANSYS Meshing & Geometry 18 May 25, 2023 02:05
Shell conduction on pipe wall Tal Eluk FLUENT 3 May 31, 2018 06:19
problem in running icoFoam Alucard OpenFOAM 2 March 17, 2012 09:01
shell conduction ezabille FLUENT 2 December 15, 2010 17:42
shell conduction @ thin walls Jiri Beran FLUENT 0 May 18, 2008 14:08
