[OpenFOAM.org] Mac-patch for OpenFOAM 2.4
Like Tree5Likes
  • 3 Post By gschaider
  • 2 Post By jjstickel
Old   May 25, 2015, 16:35
Default Mac-patch for OpenFOAM 2.4
Assistant Moderator
Bernhard Gschaider
Hi!
Attached you'll find the patch that makes OF 2.4 (I used the git-repository, but the source tarball should work too) compile on a Mac.
Instructions at http://openfoamwiki.net/index.php/In...OpenFOAM_2.3.x should work.
The patch is almost the same as for 2.3. Major difference is that the stack-trace is now delegated to lldb (which does a better job). The old stack-trace is done in addition
Bernhard
OpenFOAM-2.4.x-Mac.patch
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 4, 2015, 05:03
Default Installation OF 2.4 on Mac OS X
Willem
CFX_CFD is on a distinguished road
Hi!
I'm new to OpenFOAM and working with a terminal. I want to install the latest version of OF (2.4) on my Mac OS X Yosemite version 10.10.3. I followed the instructions you provided on http://openfoamwiki.net/index.php/In...OpenFOAM_2.3.x but now applied on the 2.4.x version.
I installed all the necessary ports as you can see below
 $ port select --summary
Name     Selected               Options
db       db48                   db48 none
gcc      mp-gcc48               mp-gcc48 mp-gcc49 none
llvm     mp-llvm-3.5            mp-llvm-3.5 none
mpi      openmpi-gcc48-fortran  openmpi-gcc48-fortran openmpi-mp-fortran none
python   python27               python26-apple python27 python27-apple none
python2  none                   python26-apple python27 python27-apple none
After going through all the instructions, I tried to run the blockMesh command in the terminal while being in the OpenFOAM/OpenFOAM-2.4.x/tutorials/incompressible/icoFoam/cavity directory but I was unsuccessful.
I got the following message:
$ blockMesh
-bash: blockMesh: command not found
I checked the other threads for tips, reinstalled all the necessary ports, tried to install other versions as well but I was not able to install OF on my computer. Could you please help me figuring out what went wrong in the installation of OF?
Thanks in advance!
CFX_CFD is offline   Reply With Quote
Old   June 22, 2015, 16:15
Patryk Wójtowicz
patrick is on a distinguished road
I am running 10.10.4 and also failed to install both 2.3 and 2.4 version. With previous system version (10.10.2 I think) installation of 2.3 went nice and easy this time I get plenty of errors when building.
Anyone succeeded installing OF 2.4 on Yosemite 10.10.4?
patrick is offline   Reply With Quote
Old   June 22, 2015, 17:24
Patryk Wójtowicz
Tried again with OF 2.4.0 and instructions (they worked on previous OS X version) from this website. Build failed again...
My ports config:
db       db48                   db48 none
pip      none                   pip27 none
Log already begins with errors:
gcc-mp-4.8 -m64 -fsignaling-nans  -ftrapping-math -fdiagnostics-color=always  -Wall -O2   -fPIC -Ddarwin dirToString.c -o /Users/Patryk/OpenFOAM/OpenFOAM-2.4.0/wmake/platforms/darwinIntel64Gcc48/dirToString
gcc-mp-4.8: error: unrecognized command line option '-fdiagnostics-color=always'
make: *** [/Users/Patryk/OpenFOAM/OpenFOAM-2.4.0/wmake/platforms/darwinIntel64Gcc48/dirToString] Error 1
no ThirdParty sources found - skipping
+ wmakePrintBuild -check
no git description found
+ /bin/rm -f 'OpenFOAM/Make/*/global.?'
+ wmakeLnInclude OpenFOAM
+ wmakeLnInclude OSspecific/POSIX
+ Pstream/Allwmake
+ wmake libso dummy
wmakeLnInclude: linking include files to ./lnInclude
/bin/sh: /Users/Patryk/OpenFOAM/OpenFOAM-2.4.0/wmake/platforms/darwinIntel64Gcc48/wmkdep: No such file or directory
SOURCE=UIPread.C ;  g++-mp-4.8 -m64 -fsignaling-nans  -ftrapping-math -fdiagnostics-color=always -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100  -IlnInclude -I. -I/Users/Patryk/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/Users/Patryk/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64Gcc48DPOpt/UIPread.o
SOURCE=UOPwrite.C ;  g++-mp-4.8 -m64 -fsignaling-nans  -ftrapping-math -fdiagnostics-color=always -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100  -IlnInclude -I. -I/Users/Patryk/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/Users/Patryk/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64Gcc48DPOpt/UOPwrite.o
SOURCE=UPstream.C ;  g++-mp-4.8 -m64 -fsignaling-nans  -ftrapping-math -fdiagnostics-color=always -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100  -IlnInclude -I. -I/Users/Patryk/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/Users/Patryk/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64Gcc48DPOpt/UPstream.o
g++-mp-4.8: error: unrecognized command line option '-fdiagnostics-color=always'
make: *** [Make/darwinIntel64Gcc48DPOpt/UIPread.o] Error 1
make: *** Waiting for unfinished jobs....
make: *** [Make/darwinIntel64Gcc48DPOpt/UPstream.o] Error 1
make: *** [Make/darwinIntel64Gcc48DPOpt/UOPwrite.o] Error 1
+ case "$WM_MPLIB" in
+ set +x
Old   August 5, 2015, 18:02
Default OpenFOAM-2.4.x-Mac.patch works for me
Jonathan
jjstickel is on a distinguished road
Thanks for the patch. Works for me on 10.10.4 with MacPorts providing dependencies and gcc-4.9 compiler.
Some hints for those having trouble. Install the following via Macports:
scotch +gcc49 -mpich +openmpi
cgal
flex
metis +gcc49
ccache
bison
boost
qt4-mac
Make sure to create and use properly the case-sensitive journaled sparse image (documented elsewhere). I link the image mountpoint (usually in /Volume) to $HOME.
Edit ~/OpenFOAM/OpenFOAM-2.4.0/etc/bashrc as follows:
export WM_NCOMPPROCS=N # add this line, N from: "sysctl -n hw.ncpu"
export WM_COMPILER=Gcc49 # change compiler you want
export WM_MPLIB=SYSTEMOPENMPI # check this, should be OK
Then,
cd ~/OpenFOAM/OpenFOAM-2.4.0/
source etc/bashrc
./Allwmake 2>&1 | tee build.log
RMacReamoinn and kubabanana75 like this.
jjstickel is offline   Reply With Quote
Old   August 13, 2015, 11:25
Ali
ali.m.1 is on a distinguished road
Hi
Do you know how to install db 48 separately? I have it on my mac (10.10.4), but when I try to set it to a port, it says
Selecting 'db48' for 'db' failed: The configuration file '/opt/local/etc/select/db/base' could not be opened.
It's like when it was installed, it never installed properly. Do you know how I can install it again?
Thanks for the help.
ali.m.1 is offline   Reply With Quote
Old   August 13, 2015, 11:48
Jonathan
Originally Posted by ali.m.1 View Post
Hi
I think this is a macports question. You would probably have better luck asking on the macports-users email list.
Old   August 13, 2015, 22:34
Default openfoam error
Juimo Pierre
Roskiki is on a distinguished road
the error message is obtained by compiling OpenFOAM on Mac YosemiteOpenFOAM-2.4.x-Mac.patch.zip
bashrc.zip
-lfiniteVolume -lmeshTools -lOpenFOAM -ldl -lpthread -lm -o /Users/Mowa/OpenFOAM23/OpenFOAM-2.4.x/platforms/darwinIntel64Gcc49DPOpt/bin/solidEquilibriumDisplacementFoam
ld: library not found for -lfiniteVolume
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[2]: *** [/Users/Mowa/OpenFOAM23/OpenFOAM-2.4.x/platforms/darwinIntel64Gcc49DPOpt/bin/solidEquilibriumDisplacementFoam] Error 1
make[1]: *** [solidEquilibriumDisplacementFoam] Error 2
make[1]: Target `application' not remade because of errors.
make: *** [stressAnalysis] Error 2
make: Target `application' not remade because of errors.
Roskiki is offline   Reply With Quote
Old   August 30, 2015, 08:53
bvangelis is on a distinguished road
I followed the instructions and everything compiled with no errors on OS X 10.10.5 with mp-gcc52. However, when running blockmesh for the cavity tutorial I am getting "Segmentation fault: 11". Any clues?
bvangelis is offline   Reply With Quote
Old   September 23, 2015, 14:43
Thumbs up Installation works without selecting db48
Tim Erhardt
kubabanana75 is on a distinguished road
Hi everyone,
first of all thanks for the patch!
I had the same issue with selecting db48. But I was able to install OpenFOAM 2.4.x on OX 10.10.5 by simply ignoring that error message .
I also used the "hints" from post #5
kubabanana75 is offline   Reply With Quote
Old   June 1, 2016, 14:55
Jeremy
j_moulton is on a distinguished road
Hi. Following your hints and the only step I don't follow is this one.
I don't have a line in my bashrc file with "sysctl -n hw.ncpu". Can I insert the line you provided as is-and where would that be?-or is there any additional work that must be included?
j_moulton is offline   Reply With Quote
Old   June 1, 2016, 17:49
Jonathan
You add the line
Where 'N' is the number of cpus on your computer. You can determine that by running "sysctl -n hw.ncpu" in a terminal. I added it to the top section where it says "USER EDITABLE PART", but it can go anywhere.
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
