[OpenFOAM.org] Current directory is not $WM_PROJECT_DIR |
June 8, 2016, 12:32 |
Rep Power: 10 |
Dear all,
I'm trying to install OpenFOAM-2.2.1 from source on Ubuntu 15.10 (I have to use a code extension developed for that version of OpenFOAM). When I try to launch ./Allwmake I get this error: Code:
./Allwmake: 4: ./Allwmake: wmakeCheckPwd: not found Error: Current directory is not $WM_PROJECT_DIR The environment variables are inconsistent with the installation. Check the OpenFOAM entries in your dot-files and source them. Has someone any idea? Thank you a lot! Jacopo
Omnia per ipsum facta sunt, et sine ipso factum est nihil, quod factum est |
June 8, 2016, 13:06 |
Rep Power: 10 |
I solved the problem. I had to add a line to source the bashrc in the bashrc of Home and not in the one of OpenFOAM and then cancel the command end-of-file in the bashrc of OpenFOAM. Now it is compiling, I'm hoping it will be succesfull!
installation by sources, openfoam 2.1.1, problem, problems, source pack |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
[OpenFOAM.org] Current directory is not $WM_PROJECT_DIR | imani | OpenFOAM Installation | 17 | September 6, 2020 08:19 |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 11:52 |
Re : Problem Installing OpenFOAM on Centos -5.3 | mohanphy | OpenFOAM Installation | 1 | February 7, 2010 19:09 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
