[OpenFOAM.com] How to install a text editor in the Docker container?
Like Tree3Likes
  • 1 Post By piu58
  • 2 Post By CFDOnlineyangdaxia
Old   April 9, 2017, 21:51
Default How to install a text editor in the Docker container?
CFDOnlineyangdaxia is on a distinguished road
Hi everybody
I have recently installed OpenFOAMplus with the purpose of doing a collage project.
Since I am a linux & docker & CFD newbie, I am in trouble,
By following the instructions, I had run ./startOpenfoam+ and everything was fine but one, and that is when I want to open a text file from the container, this message appears
bash-4.1$ gedit 1.py
bash: gedit: command not found
I sent an email to the OpenFOAM staffs and they said that I should install gedit in the container, but I was unable to find out the way of doing that.
On the other hand, I know how to pull an image from the docker hub, such as mary/gedit, but does it make any sense? I mean, should I just add an extra command in OpenFOAMplus so I can run the editor inside the environment?
Please help me, thanks in advance
CFDOnlineyangdaxia is offline   Reply With Quote
Old   April 10, 2017, 00:30
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
vi should be installed. You may use that. It is slightly strange for non unix users, so read a short introduction first.
wyldckat likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   April 10, 2017, 07:31
Thank you bro, vi is indeed installed and I can now edit files freely.
A short tutorial of vi for anyone who might be interested in learning how to use it:
https://www.washington.edu/computing/unix/vi.html
wyldckat and kcc49 like this.
[OpenFOAM.com] Docker vs Not Docker v2 AND installing editors into Docker u2berggeist OpenFOAM Installation 1 July 10, 2018 02:58
[OpenFOAM.com] v1606+ Install pb with Docker on OSX El Capitan BPich OpenFOAM Installation 3 October 10, 2016 18:52
OpenFoam Parallel run on in docker container shang OpenFOAM Running, Solving & CFD 0 September 8, 2016 14:54
[OpenFOAM.com] Docker OpenFOAM install error on Mac OS X dersh OpenFOAM Installation 10 May 6, 2016 12:49
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 19:00
