[OpenFOAM.com] Missing variables
Old   July 15, 2016, 05:03
Default Missing variables
badoumba
badoumba is on a distinguished road
Hi!
After having installed OpenCFD-OpenFOAM4WindowsInstaller_v1606+.exe, no env variables seem to be registered in my Windows 7 environment.
Is this has to be a manual process? If so where can I find all the names/paths?
Thanks
badoumba is offline   Reply With Quote
Old   July 15, 2016, 08:27
pgh
Pawan Ghildiyal
pgh is on a distinguished road
you need to click on first OF_ENV_CReate shorcut from Desktop and then need to click on OpenFOAM_start which will open terminal with openfoam environment set .
pgh is offline   Reply With Quote
Old   July 15, 2016, 09:01
badoumba
Hi Pawan,
Yes, already did this and in this order.
Is there a way to check that everything in properly installed? OpenFOAM_start prompts me with the following :
Does it means that everything's fine?
Thanks
Old   July 15, 2016, 09:28
pgh
Pawan Ghildiyal
Yes.everything is fine .. you need to work on this terminal . http://openfoam.com/download/install-windows.php see instruction in link on how to run tutorial
Old   July 15, 2016, 09:31
badoumba
Hi Pawan,
I actually refered to this page for the installation + the README file.
But no $FOAM_TUTORIALS set, and no /opt folder in my Windows anywhere.
Am I missing something? Isn't /opt a linux folder? Is there a link with the VM then? Not easy setting
Old   July 15, 2016, 09:38
pgh
Pawan Ghildiyal
Hi .. You need to do it via terminal as it is located in image(i.e can be accessed via virtual box) You can access it via terminal ..you cannot access it via browisng the windows .
Old   July 15, 2016, 09:45
badoumba
ok Pawan, thanks for your time and your help!
Some variables not loading in Tecplot nick.l.thomas Tecplot 1 October 25, 2018 17:48
missing variables in cfd post umbsab988 FLUENT 5 June 20, 2018 03:50
what is syntax error : missing ')' before ';' aleisia Fluent UDF and Scheme Programming 8 March 10, 2015 15:42
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 04:23
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
