[OpenFOAM.com] v1606+ Compiling/installing on ubuntu 14.04 - error
Old   August 9, 2016, 17:04
Default v1606+ Compiling/installing on ubuntu 14.04 - error
anonymous
philm is on a distinguished road
Hello everyone,
I am currently working on compiling the source of openFoam. I am using the latest version of openFoam. I am also following the instructions outlined in the following webpost:
www.openfoam.com/download/install-source.php.
When I execute the following command:
source ~/OpenFOAM/OpenFOAM-v1606+/etc/bashrc
I receive the following error message:
cc: error: unrecognized command line option '--showme:link'
I am not sure what could be causing the issue. I have installed OpenFOAM on a number of different machines and this is my first time running into the issue.
Would anyone have any idea on how I can solve this?
philm is offline   Reply With Quote
Old   September 11, 2016, 13:19
Retired Super Moderator
Bruno Santos
Quick answer: The problem is that "bashrc" is configured to use the system's Open-MPI installation by default, not MPICH (from what I can see from this thread of yours: http://www.cfd-online.com/Forums/lou...h-cluster.html).
There are a few possible solutions, depending on how exactly you installed MPICH. The simplest is to do the following steps:
  1. Edit the file "~/OpenFOAM/OpenFOAM-v1606+/etc/bashrc".
  2. Find this line:
    export WM_MPLIB=SYSTEMOPENMPI
  3. Change it to this:
    export WM_MPLIB=MPICH
  4. Save and close this file.
  5. Now edit the file "~/OpenFOAM/OpenFOAM-v1606+/etc/config.sh/mpi".
  6. Find this line:
    MPICH)
  7. Update the settings below that line according to the installation that you have of MPICH.
  8. Save and close this file.
  9. Run:
    and try again.
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
