[OpenFOAM.com] Compiling Error of wallHeatFluxIncompressible utility |
November 20, 2019, 01:07 |
#1 | |
Mondal
Rep Power: 7 |
Hi Foamers,
I was trying to compile wallHeatFluxIncompressible in OpenFOAM 6 but showing the following error. Quote:
Did this error appear before in front of you? Or if you know the solution, please tell me. Thanks in advance. Cheers Razon |
November 28, 2019, 02:17 |
Compiling Error
#2 | |
Mondal
Rep Power: 7 |
Any help regarding this issue? I am not finding any thread related to this problem so that I can help myself. Thank you very much, everyone. cheers Razon |
November 29, 2019, 11:36 |
Herpes Free Engineer
Rep Power: 12 |
After a certain version, some of the dependencies were changed in OF (such as turbulenceModel.H). Try to adjust the dependencies to the new version, or use older OpenFOAM versions like 2.x, don't know.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
OF 6 wallHeatFlux utility not working on chtMultiRegionFoam tutorial | troparry | OpenFOAM Post-Processing | 1 | January 10, 2022 06:12 |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
Problem in compiling the makeAxialMesh utility | Belmar | OpenFOAM Programming & Development | 1 | July 18, 2017 15:17 |
wallHeatFlux Calculation wrt utility version | ahmet | OpenFOAM Post-Processing | 1 | December 18, 2016 19:45 |
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! | zfaraday | OpenFOAM Post-Processing | 0 | February 5, 2015 16:47 |
