[OpenFOAM.com] v1606+ flag provided but not defined: --privileged
Old   August 23, 2016, 14:16
Default v1606+ flag provided but not defined: --privileged
tohagit is on a distinguished road
Hello
i installed openfoam using the windows installer
I am trying to run OpenFOAM_Start, after I ran OF_Env_Create as the installation guide says, i get the next error message (windows 7 64 bit), any advices?
Thanks!
C:\Program Files (x86)\ESI\OpenFOAM\1606>"C:\Program Files (x86)\ESI\OpenFOAM\16
06\Windows\Scripts\of_start_container.exe" -Arguments "C:\Program Files\Docker T
oolbox\;C:\Program Files\Git\bin"
Starting "default"...
(default) Check network to re-create if needed...
(default) Waiting for an IP...
Machine "default" was started.
Waiting for SSH to be available...
Detecting the provisioner...
Started machines may have new IP addresses. You may need to re-run the `docker-m
achine env` command.
of_plus_1606
See 'C:\Program Files\Boot2Docker for Windows\docker.exe exec --help'.
Stopping "default"...
tohagit is offline   Reply With Quote
Old   September 19, 2016, 05:34
pgh
Pawan Ghildiyal
pgh is on a distinguished road
Hi.. You still facing the issue ?
pgh is offline   Reply With Quote
Old   September 21, 2016, 16:36
SCK
SCK is on a distinguished road
I have the exact same problem....
SCK is offline   Reply With Quote
Old   September 30, 2016, 19:05
Default [OpenFOAM plus][v1606+] Problems installing on windows 10
rob cooper
base1379 is on a distinguished road
So i'm installing for the first time on windows 10. I followed the OF_Windows_Guide_V1606+.pdf, and it says to enable hardware assisted virtualization. I scoured my BIOS, but didn't find this option. Also I looked through task manager but didn't see anything obvious... in the guide it says "In Windows8, and Windows10 it can be checked via the Task Manager.", how is that done?
When i try to run OpenFOAM_Start, i get (see attached OpenFOAM_Start.png)
then the command window closes and nothing happens.
My motherboard is about 5 years old, maybe I need newer hardware?
thanks,
rob
base1379 is offline   Reply With Quote
Old   September 30, 2016, 19:21
rob cooper
In System Information, it says "Hyper-V - Virtualization Enabled in Firmware Yes". Is that the same thing as "Hardware assisted virtualization"?
Old   October 6, 2016, 02:55
djfanf is on a distinguished road
I have exactly the same problem although virtualization is enabled. I think the Problem comes from something else, anyone having this issue and solved this ?
Thanks
djfanf is offline   Reply With Quote
Old   October 19, 2016, 06:38
pgh
Pawan Ghildiyal
Hi Rob
Are you manage to solve the issue ?
Regards
Pawan
[ICEM] How can I define different zones in ICEM? llrr ANSYS Meshing & Geometry 14 February 12, 2017 13:44
UDF link fortran source yorelchr Fluent UDF and Scheme Programming 0 February 7, 2013 03:44
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 04:06
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
OpenFOAM13 for Mac OSX Darwin 104 hjasak OpenFOAM Installation 70 September 24, 2010 05:06
