[foam-extend.org] Foam extend 3.2 installation issue |
February 26, 2017, 10:22 |
Alessio
Good evening, i've installed foam extend 3.2 but when i launch it from the terminal i receive this message: error while loading shared libraries: libbasicSolidThermo.so: cannot open shared object file: No such file or directory. How can i fix it? Thanks in advance
Alessio |
March 25, 2017, 15:01 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Alessio,
Sorry for taking so long for someone to get back to you one this. Have you solved this problem? If not, please run the following commands: Code:
fe32 foam ./Allwmake > log.make 2>&1 gzip < log.make > log.make.gz In addition to this, it would be useful to know which application did you try to run that gave you this error message? Best regards, Bruno
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
Sig Density Based Solver installation with FOAM Extend 3.2 | qjh888 | OpenFOAM Bugs | 0 | September 21, 2016 08:16 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
