[Other] in the installation, the "gedit" step failed
Like Tree1Likes
  • 1 Post By JoshuaB-L
Old   March 21, 2017, 02:49
Default in the installation, the "gedit" step failed
Yang Zhengnan
YoungZN is on a distinguished road
hello everyone
i firstly installed OpenFOAM, and there is a problem.
i have installed the OpenFOAM document and the Thirdparty document.
and next i need to use
gedit $HOME/.bashrc
to set the environment.
but i failed, and there are tips on screen
error: XDG_RUNTIME_DIR not set in the environment.
(gedit:2858): Gtk-WARNING **: cannot open display:
i don't know much about the Linux system, so i need help!
YoungZN is offline   Reply With Quote
Old   March 25, 2017, 14:11
Retired Super Moderator
Bruno Santos
Greetings YoungZN and welcome to the forum!
A few questions, so that we are able to diagnose the problem:
  1. Which Linux Distribution are you using?
  2. Which installation instructions did you follow?
  3. Are you logged in directly in the workstation where OpenFOAM has been installed or are you accessing remotely?
    1. If you are accessing remotely, which protocol are you using? SSH or VNC?
Best regards,
Bruno
Old   September 10, 2019, 12:03
Default Problem with user configuration on OpenFOAM v7 Ubuntu
Joshua
JoshuaB-L is on a distinguished road
Hello I had the same issue. It would be great to know how to problem solve.
I'm installing OpenFOAM v7 for Windows 10 (win64)
On Ubuntu following these installation instructions:
https://openfoam.org/download/7-ubuntu/
I successfully installed OpenFOAM but when I came to User Configuration
I typed:
gedit ~/.bashrc
Which returned:
~$ gedit ~/.bashrc
Unable to init server: Could not connect: Connection refused
(gedit:14): Gtk-WARNING **: 17:56:52.440: cannot open display:
I'm not sure what the issue is.
Please can you help?
Best,
Josh
Vinay94 likes this.
JoshuaB-L is offline   Reply With Quote
Old   October 9, 2019, 19:01
Bruno Santos
Quick answer @Josh: Follow the instructions at https://openfoam.org/download/windows-10/ - namely section "Enabling Graphical Applications"
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 05:28
[foam-extend.org] 3.2 Installation in Debian 8.5 jsm OpenFOAM Installation 2 June 19, 2016 10:53
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 07:09
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 15:00
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
