[OpenFOAM.org] Openfoam 4.1 conflicts with Cuda 7.5 on ubuntu 16.04 |
March 6, 2017, 01:47 |
Hilbert
Rep Power: 10 |
Hi all,
For a while I have been running openfoamV4.1 installed via apt-get and that has all gone smoothly. This afternoon I though I would have a look at Cuda, the accelerated computing toolbox from Nvidia. When I load Cuda in my .bashrc file I get the following error in openfoam: reconstructPar: error while loading shared libraries: libfiniteVolume.so: cannot open shared object file: No such file or directory And this happens when I try to run a solver as well. When remove cuda from my bashrc file again all is merry again. So something in cuda is conflicting with OpenFoam. Has anybody seen this before/ have an idea on how to fix it? Cheers |
March 25, 2017, 14:55 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Hillie,
A few questions:
Bruno
April 3, 2017, 21:59 |
Hilbert
Rep Power: 10 |
Hi Bruno,
Thanks for you reply. I did solve the issue in the end. For the cuda installation I followed a walkthough on a forum, and not the official nvidia guide. In the end changing the cuda lines in my .bashrc file to the lines below did the trick. export PATH=$PATH:/usr/local/cuda-8.0.61/bin export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda-8.0.61/lib64 I haven't spend much time with it yet but I wanted to have a look at GPU assisted solvers for OpenFOAM,. Cheers, Hilbert |
[OpenFOAM.org] I have trouble installing openfoam 5.0 on ubuntu 16.04 | haydii | OpenFOAM Installation | 5 | December 27, 2018 10:56 |
[OpenFOAM.org] openFoam 2.3.x install on Ubuntu 16.04 in windows 10 | AndyBloke | OpenFOAM Installation | 5 | April 8, 2018 17:57 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
OpenFOAM 4.1 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 0 | October 13, 2016 06:42 |
Openfoam 2.1 installation in ubuntu 12.04 | jsm | OpenFOAM Installation | 11 | May 7, 2012 04:56 |
