[OpenFOAM.com] [Windows] "ParaView reader module library does not exist" |
May 15, 2017, 16:21 |
Rep Power: 8 |
Hi everyone,
I recently installed openFoam on my Windows 7 computer to get started on my masters studies. The installation itself was a pain, but now I'm going through the tutorial attached to the software with the cavity flow example and I'm having trouble with the "paraFoam" command. I tried the commands stated in the message to 'reset' the plug ins, but that didn't change the situation at all, I kept getting the same message. In an effort to fix this, I tried installing paraView 5.4.0 separately, but I guess it's not connected to openFoam in any way, nor does openFoam recognize it. I read a bunch of forum posts that recommended taking the .foam files and opening them in paraView manually, but I can't find the associated directory to actually manually open the .foam files. The installation is a brand new one, on a Windows 7 64 bit computer. I have a virtual machine installed on this thing, but I can't get it to work, so I've been using Windows 7 for this exclusively (I know...I know....). Any ideas? I'm at a dead end and have no idea where to go from here! Regards, Ethan Last edited by Eefoe; May 16, 2017 at 12:53. Reason: Title typo |
May 28, 2017, 03:58 |
Pawan Ghildiyal
Rep Power: 10 |
Hi
Note paraFoam is not supported via window installation . User need to install separate paraview which can be downloaded from https://www.paraview.org/download/ Thanks Pawan |
June 1, 2017, 13:35 |
Rep Power: 8 |
It didn't want to work with me, so I ended up dual-installing Ubuntu in parallel with my Windows 7 installation. I haven't resolved the issue, per se, but I was able to mitigate it. -Ethan |
paraview 5.4.0, tutorials, windows 7 |
[OpenFOAM.org] paraView reader module build problem | fusij | OpenFOAM Installation | 52 | March 7, 2018 23:40 |
[OpenFOAM] Cavity Tutorial: ParaView starts, cannot find reader | mfrain | ParaView | 7 | June 18, 2012 22:14 |
OpenFOAM-2.0.x on Ubuntu 11.10 | kpsl | OpenFOAM Installation | 43 | January 18, 2012 23:17 |
[OpenFOAM] ParaView reader plugin | wreck55 | ParaView | 1 | April 1, 2009 03:32 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
