[OpenFOAM.org] Error in installation of OpenFOAM-dev on Ubuntu14.04 (ptscotchDecomp & mpicxx issue) |
Rajib Roy
Rep Power: 12 ![]() |
I am facing an error while compiling OpenFOAM-dev from sources in my Ubuntu 14:04 machine while following the instructions on OpenFOAMwiki page. I am installing it with "Debug" option and GCC compilers. I am stuck in step 12.2 and the system info & error message is as follows:
Sys info: Code:
rroy@Precision:~/OpenFOAM/OpenFOAM-dev-debug$ uname -a Linux Precision 4.4.0-78-generic #99~14.04.2-Ubuntu SMP Thu Apr 27 18:49:46 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux Code:
wclean ptscotchDecomp wmake ptscotchDecomp wmake ptscotchDecomp wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file ptscotchDecomp.C g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O0 -fdefault-inline -ggdb3 -DFULLDEBUG -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/usr/local/include -pthread -I/home/rroy/OpenFOAM/ThirdParty-dev-debug/platforms/linux64GccDPInt32/scotch_6.0.3/include/openmpi-system -I/home/rroy/OpenFOAM/ThirdParty-dev-debug/platforms/linux64GccDPInt32/scotch_6.0.3/include -I/usr/include/scotch -I../decompositionMethods/lnInclude -IlnInclude -I. -I/home/rroy/OpenFOAM/OpenFOAM-dev-debug/src/OpenFOAM/lnInclude -I/home/rroy/OpenFOAM/OpenFOAM-dev-debug/src/OSspecific/POSIX/lnInclude -fPIC -c ptscotchDecomp.C -o /home/rroy/OpenFOAM/OpenFOAM-dev-debug/platforms/linux64GccDPInt32DebugSYSTEMOPENMPI/src/parallel/decompose/ptscotchDecomp/ptscotchDecomp.o In file included from /usr/local/include/mpi.h:2231:0, from ptscotchDecomp.C:36: /usr/local/include/mpicxx.h:2737:34: error: declaration of C function ‘void MPI::Init(int&, char**&)’ conflicts with extern void Init(int &, char **& ); ^ /usr/local/include/mpicxx.h:2736:13: error: previous declaration ‘void MPI::Init()’ here extern void Init(void); ^ /usr/local/include/mpicxx.h:2739:45: error: declaration of C function ‘int MPI::Init_thread(int&, char**&, int)’ conflicts with extern int Init_thread(int &, char **&, int ); ^ /usr/local/include/mpicxx.h:2738:12: error: previous declaration ‘int MPI::Init_thread(int)’ here extern int Init_thread(int); ^ make: *** [/home/rroy/OpenFOAM/OpenFOAM-dev-debug/platforms/linux64GccDPInt32DebugSYSTEMOPENMPI/src/parallel/decompose/ptscotchDecomp/ptscotchDecomp.o] Error 1 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer: The output indicates that you are not using the default Open-MPI system installation, given that it's using the file "/usr/local/include/mpi.h".
Which specific MPI version are you using? It doesn't seem to be compatible or perhaps you need to adjust the OpenFOAM environment variable "WM_MPLIB" to the correct setting. For getting the specific version of Open-MPI that you are using, try running this command: Code:
mpirun --version which mpirun
installation, mpi error, openfoam-dev |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
OpenFOAM 2.2.2 source pack installation on Xubuntu 13.10 | zordiack | OpenFOAM Installation | 1 | October 26, 2013 13:08 |
Issue installation OpenFOAM - libopen-rte.so.0 | Voyage_gui | OpenFOAM | 1 | August 12, 2011 03:46 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 04:48 |
