[foam-extend.org] upgrade to opensuse leap and now problems to install ofext3.0
Like Tree1Likes
  • 1 Post By wyldckat
Old   June 15, 2017, 12:27
Default upgrade to opensuse leap and now problems to install ofext3.0
tomdylan's Avatar
Tom Dylan
tomdylan is on a distinguished road
Dear foamers,
After having upgraded to openSuse Leap I succeeded installing ofext3.0. But I was no able to compile any solver due to some references of the basic packages (mathematicalConstant) keep unresolved:
Making dependency list for source file boundaries/fixedDisplacementZeroShear/fixedDisplacementZeroShearFvPatchVectorField.C
Making dependency list for source file boundaries/standingWaveTheory/standingWaveTheoryFvPatchScalarField.C
Making dependency list for source file boundaries/interpolateTimeVaryingTotalTraction/interpolateTimeVaryingTotalTractionFvPatchVectorField.C
Making dependency list for source file boundaries/linearVaryingTotalTraction/linearVaryingTotalTractionFvPatchVectorField.C
Making dependency list for source file boundaries/zeroTotalTraction/zeroTotalTractionFvPatchVectorField.C
Making dependency list for source file boundaries/fixedTotalTraction/fixedTotalTractionFvPatchVectorField.C
Making dependency list for source file pDependElastPlastBiotFoam.C
g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -I/home/hector/OpenFOAM/OpenFOAM-3.0.x/src/meshTools/lnInclude -I/home/hector/OpenFOAM/OpenFOAM-3.0.x/src/finiteVolume/lnInclude -I/home/hector/OpenFOAM/OpenFOAM-3.0.x/src/OpenFOAM/global/constants/mathematical -IincrementTractionDisplacement/lnInclude -IlnInclude -I. -I/home/hector/OpenFOAM/OpenFOAM-3.0.x/src/OpenFOAM/lnInclude -I/home/hector/OpenFOAM/OpenFOAM-3.0.x/src/OSspecific/POSIX/lnInclude   -fPIC -c pDependElastPlastBiotFoam.C -o Make/linux64GccDPInt64Opt/pDependElastPlastBiotFoam.o
In file included from pDependElastPlastBiotFoam.C:60:0:
readSoilProperties.H: In function ‘int main(int, char**)’:
readSoilProperties.H:70:39: error: ‘mathematicalConstant’ has not been declared
     scalar k = ((1 + sin(varPhi/180.0*mathematicalConstant::pi))/(1 - sin(varPhi/180.0*mathematicalConstant::pi))).value();
readSoilProperties.H:70:88: error: ‘mathematicalConstant’ has not been declared
readSoilProperties.H:72:39: error: ‘mathematicalConstant’ has not been declared
     scalar m = ((1 + sin(varPsi/180.0*mathematicalConstant::pi))/(1 - sin(varPsi/180.0*mathematicalConstant::pi))).value();
readSoilProperties.H:72:88: error: ‘mathematicalConstant’ has not been declared
pDependElastPlastBiotFoam.C:77:9: error: ‘solverPerformance’ is not a member of ‘Foam::lduMatrix’
         lduMatrix::solverPerformance solverPerfP;
pDependElastPlastBiotFoam.C:77:38: error: expected ‘;’ before ‘solverPerfP’
pDependElastPlastBiotFoam.C:78:9: error: ‘solverPerformance’ is not a member of ‘Foam::lduMatrix’
         lduMatrix::solverPerformance solverPerfDU;
pDependElastPlastBiotFoam.C:78:38: error: expected ‘;’ before ‘solverPerfDU’
pDependElastPlastBiotFoam.C:82:35: error: ‘class Foam::Time’ has no member named ‘controlDic’
         word correct=word(runTime.controlDic t().lookup("correctPlasticity"));
pDependElastPlastBiotFoam.C:98:6: error: ‘solverPerfP’ was not declared in this scope
      solverPerfP = pEqn.solve();
pDependElastPlastBiotFoam.C:101:25: error: no match for ‘operator<<’ (operand types are ‘Foam::Ostream’ and ‘void’)
     Info<< "p_relax = " << p.relax() << " Pa\n";
and some more code I left
Surprisingly, everything was OK when working under the previous openSuse 13.1
EXE_INC = \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/OpenFOAM/global/constants/mathematical \
EXE_LIBS = \
    -lfiniteVolume \
    -llduSolvers \
    -lmeshTools
It looks like some other libs should be included (or the sequence be changed ?). But I have no clue...
Any hints warmly appreciated
Tom
Last edited by tomdylan; June 15, 2017 at 14:11. Reason: title was not conciese enough
tomdylan is offline   Reply With Quote
Old   June 18, 2017, 09:11
tomdylan's Avatar
Tom Dylan
Somewhat in despair I moved to openFoam ext 4 and made sure that the installation process (under openSuse Leap 42.2) was OK. I successfully managed to compile and to run the plate hole tutorial of the solid mechanics branch.
But when I went to my code, which under oFext3.0 was running fine, an previously unknown error appeared:
pDependElastPlastBiotFoam.C: In function ‘int main(int, char**)’:
Apparently the solverPerformance call is unknown/undeclared in the version compiled. The only thing I found out, was that the =solverPerformance=-class is hidden in
=lduMatrix=.
I have absolutely no idea how to handle/correct this kind of problems...
Tom
Old   June 25, 2017, 11:41
Retired Super Moderator
Bruno Santos
Quick answer: Replace all occurrences of:
with:
lduSolverPerformance
Old   June 29, 2017, 16:58
tomdylan's Avatar
Tom Dylan
Thank you very much for this hint, Bruno!
Now the solver is compiled without any errors.
And that was the reason for confusion:
lduMatrix::solverPerformance -> lduSolverPerformance
Is there any documentation out there of the syntax changes during the evolution of o30ext - o40ext?
Next time I might check the errors myself.
Anyway installation of o40x on openSuse Leap 42.2 was successful. Thanks again for your support!
Tom
Old   July 2, 2017, 15:13
Bruno Santos
Not that I'm aware of. You would have to look at the git history for foam-extend 4.0 in order to see the comments on each commit on what changed.
I knew about this bug fix because I had to do it myself last year for the FSI toolkit.
You're welcome!
reverseila likes this.
of3.0x, opensuse leap, unresolved inc
