[OpenFOAM.com] How to update OpenFOAM to a new version? from v1612 to v1706
Old   September 6, 2017, 04:01
Default How to update OpenFOAM to a new version? from v1612 to v1706
rbaCFD is on a distinguished road
Hi all,
I installed OpenFOAM v1612 in February and now I want to update to v1706. I have read that instead of installing binary files that OF provides, is better to use the Build Guide:
http://openfoam.com/code/build-guide.php
However, I donīt understand what is the purpose of that. Do I need to compile OpenFOAM every time I want to use the updates of the new version?
Thanks in advance. Kind regards,
Ricardo
rbaCFD is offline   Reply With Quote
Old   September 6, 2017, 18:07
Retired Super Moderator
Bruno Santos
Greetings Ricardo,
It depends on how and where you use OpenFOAM.
Building from source code is useful if you are using OpenFOAM on a cluster, supercomputer or a high performance workstation, so that the compiler can adjust the binaries to the hardware where it's being used, along with using the software stack that those machines already have installed.
But if you use on a laptop with a CPU that has 4 cores and only run for a few hours a day, then installing the pre-built binary might be good enough for your daily use.
Technically, you can have more than one version and forks/variants of OpenFOAM installed. This is usually done so that users can compare what changed between versions, may it be regarding the case set-up or due to a modification in the solvers.
Best regards,
Bruno
Old   September 7, 2017, 03:46
Originally Posted by wyldckat View Post
Greetings Ricardo,
Best regards,
Bruno
Thanks Bruno
Kind regards
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
Sudden contration MrAndersDk OpenFOAM Running, Solving & CFD 30 October 11, 2018 03:23
simpleFoam convergence issue Harnoor OpenFOAM Running, Solving & CFD 13 November 16, 2016 08:23
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 03:18
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
