[foam-extend.org] Install foam-extend 1.6 from source, scotchDecomp error.
Old   September 28, 2017, 11:17
Default Install foam-extend 1.6 from source, scotchDecomp error.
Katt
Katt is on a distinguished road
Hi guys;
I am using RedHat Linux with no internet/ no administrative privileges (theres no other way, I have to deal with this "fortunately/ unfortunately").
I have installed several versions of OpenFOAM/ Foam-Extend on my laptop as a sudo user and never came across any problem.
Coming to my case, for many days, I have been trying to build Foam-Extend-1.6 from the source code and install ThirdParty libraries manually. That is, download required libraries and run the ThirdParty script individually.
Initially I came across MPI problem which I solved and presently struggling with scotchDecomposition problem.
After running the ThirdParty stages individually, I run the FE-1.6 installation but come across the following erros:
+ wmake libso scotchDecomp
SOURCE=scotchDecomp/scotchDecomp.C ; ---------------------------
SOURCE=engineScotchDecomp/engineScotchDecomp.C ; --------------
scotchDecomp/scotchDecomp.H: 39:33: error: decompositionMethod.H: No such file or directory
and the errors continue in the lnInclude/scotchDecomp.H.
I hope I am not the 1st one struggling with these weird administrative problems and would appreciate if anyone can help me out.
Katt is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 06:25
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
