November 15, 2017, 15:40 |
OpenFOAM 5.0 on Fedora 26
Chris Pounds
Rep Power: 11 |
I attempted installing OF5 on an install of F26 using the instructions for the Docker virtualisation. The pitz test case ran but parafoam did not install correctly and I'm having a hard time figuring out exactly where OF has been installed. I'm also not a fan of running cases through Docker.
Is there a long form of the install instructions for OF5 on Fedora that does not involve Docker? Otherwise I'll revert to OF4 running on bare metal. |
December 30, 2017, 11:37 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: In principle, you should be able to follow the instructions given here: OpenFOAM 4.1 on Fedora 24 - but change "4-1" to "5-0" and "41" to "50".
The other possibility is to try and follow the instructions given here: https://openfoamwiki.net/index.php/I...OAM-dev/Fedora - but adapt from "OpenFOAM-dev" to "OpenFOAM-5.x". Note: I have not written either one of those instructions and have not been able to test them myself.
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
[OpenFOAM.org] Questions about using the tutorials for OpenFOAM 5.0 on Ubuntu 16.04.3 | pisherwood | OpenFOAM Installation | 4 | May 27, 2018 12:57 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 11:50 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
Is OpenFOAM available for Fedora 20? | peter.pan | OpenFOAM Installation | 2 | May 24, 2014 04:03 |
