[OpenFOAM.org] Need Help to Install OpenFoam on IBM HPC
Old   November 19, 2017, 05:46
Default Need Help to Install OpenFoam on IBM HPC
Mazari Redha
redmaz is on a distinguished road
I have IBM cluster (HPC 4.1.1.1) with 32 nodes installed on RHEL 6.4, have IBM PMPI, and gcc version 4.4.7
I want to Install OpenFoam.
Please tell me which version can I install on it .
Any hint on how to install it? thank you
redmaz is offline   Reply With Quote
Old   December 30, 2017, 11:52
Retired Super Moderator
Bruno Santos
Quick answer: In theory, you can install any OpenFOAM version in that cluster. The only problem might be "which version is the easiest to be installed".
If I remember correctly, OpenFOAM 2.2 was the last version that could still be compiled with GCC 4.4.
For newer versions of OpenFOAM, you will either need to request your administrator to provide a more recent version of GCC or build a newer version of GCC yourself.
You can find several installation instructions for CentOS/RHEL 6.x here: https://openfoamwiki.net/index.php/C...FOAM_on_CentOS - although most of them will build its own custom GCC version.
As for using PMPI (is it Platform MPI?), I haven't used it myself with OpenFOAM. But in theory, it's a matter of changing the value defined for the variable "WM_MPLIB" in "OpenFOAM-*/etc/bashrc" and then edit the respective entry in "OpenfOAM-*/etc/config*/settings*".
ibm hpc rhel pmpi
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
[OpenFOAM.org] Install OpenFOAM 2.4.x using system Scotch cbcoutinho OpenFOAM Installation 7 October 16, 2019 19:12
[OpenFOAM.com] Docker OpenFOAM install error on Mac OS X dersh OpenFOAM Installation 10 May 6, 2016 12:49
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
