Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] problem with parafoam: "Read float past end of buffer"
Like Tree2Likes
  • 2 Post By mzzmrt
Old   May 18, 2018, 15:36
Default problem with parafoam: "Read float past end of buffer"
Osman is on a distinguished road
I have OpenFoam 4.0 and foam-extend 4.0 installed together in the same machine. I do not know why while working with fe40 parafoam does not work but with OF40, it is working. While I am running parafoam command in the terminal for fe40, the following lines are appearing:
created temporary 'cavity.OpenFOAM'
ERROR: In /build/paraview-arsa8T/paraview-5.0.1+dfsg1/ParaViewCore/ServerImplementation/Core/vtkSIProxy.cxx, line 310
vtkSISourceProxy (0x3690640): Failed to create vtkXdmfReader. Aborting for debugging purposes.
Can someone give some solutions for this problem? Thanks.
Osman is offline   Reply With Quote
Old   May 22, 2018, 04:15
mzzmrt is on a distinguished road
paraFoam -nativeReader
EmadTandis and aerosuraj like this.
mzzmrt is offline   Reply With Quote
Old   March 1, 2019, 07:16
Emad Tandis
EmadTandis is on a distinguished road
It solved the problem!
Thanks
EmadTandis is offline   Reply With Quote
parafoam problem
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 10:00
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 08:16
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 04:59
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
