[OpenFOAM.com] Problem installing Openfoam from source. Allwmake doesn't work
Like Tree2Likes
  • 2 Post By wyldckat
Old   November 23, 2018, 09:48
Default Problem installing Openfoam from source. Allwmake doesn't work
Martin
artymk4 is on a distinguished road
I have Ubuntu and I installed OpenFOAM from source. It is installed in /home/<user>/OpenFOAM/OpenFOAM-v1806
When I run "icoFoam -help" in Terminal, I get this:
Command 'icoFoam' not found, but can be installed with:
sudo apt install openfoam
I manually edited file /home/<user>/.bashrc and added this at the end:
source ~/OpenFOAM/OpenFOAM-v1806/etc/bashrc
After some reading I found out I might need to compile Openfoam first. So I ran ./Allwmake and got this error. What am I doing wrong?
$ ./Allwmake
2018-11-23 15:43:15 +0100
Starting OpenFOAM-v1806
  Gcc system compiler
  linux64GccDPInt32Opt, with SYSTEMOPENMPI openmpi-system
flex -o /home/ubuntwo/OpenFOAM/OpenFOAM-v1806/wmake/platforms/linux64Gcc/wmkdep.c wmkdep.l && gcc -m64 -DOPENFOAM=1806 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3   -fPIC /home/ubuntwo/OpenFOAM/OpenFOAM-v1806/wmake/platforms/linux64Gcc/wmkdep.c -o /home/ubuntwo/OpenFOAM/OpenFOAM-v1806/wmake/platforms/linux64Gcc/wmkdep
/bin/sh: 1: flex: not found
Makefile:76: recipe for target '/home/ubuntwo/OpenFOAM/OpenFOAM-v1806/wmake/platforms/linux64Gcc/wmkdep' failed
make: *** [/home/ubuntwo/OpenFOAM/OpenFOAM-v1806/wmake/platforms/linux64Gcc/wmkdep] Error 127
artymk4 is offline   Reply With Quote
Old   December 4, 2018, 17:03
Retired Super Moderator
Bruno Santos
Quick answer: "flex not found" means that the "flex" package hasn't been installed. You should follow the instructions given here: https://www.openfoam.com/documentati...quirements.php - it's indicated at the start of the instructions for source code page that you provided
mcfdma and coco.dss like this.
allwmake, source, ubuntu
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
Re : Problem Installing OpenFOAM on Centos -5.3 mohanphy OpenFOAM Installation 1 February 7, 2010 19:09
