[OpenFOAM.com] Does GAMG solver have something to do with CGAL or boost? |
Syavash Asgari
Rep Power: 18 ![]() |
Dear mates,
I have tried to install both OF1812 and the recently released OF1906 on a cluster. However, I cannot manage to use GAMG solver in either versions, not even in the tutorial cases. It gives me error that I cannot understand. Now, my question here, is there a connection between CGAL/boost installation and proper compilation of GAMG solver? I ask because I could not manage to install CGAL/boost. However, OpenFOAM still has remained functional and I can use PCG algorithm and other stuff. Kind Regards, Syavash |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer: GAMG should not depend on CGAL nor Boost. And if it did, you would likely never been able to run the solver, since it would not have compiled either.
Without being able to see the error message you are seeing, there isn't much we can suggest. My best guess is that perhaps it fails if you try to decompose a 100000 cell case with 200 cores, which results in 500 cells per subdomain, which can easily result in the default GAMG settings for minimum cells in the sub-matrix being larger then the number of faces on a patch.
#3 | |
Syavash Asgari
I agree that I did not provided enough info. Here is the error message I get from executing ./Allrun in tutorial "airfoil2D" from simpleFoam: Code:
Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model SpalartAllmaras Selecting patchDistMethod meshWave RAS { RASModel SpalartAllmaras; turbulence on; printCoeffs on; sigmaNut 0.66666; kappa 0.41; Cb1 0.1355; Cb2 0.622; Cw2 0.3; Cw3 2; Cv1 7.1; Cs 0.3; } No MRF models present No finite volume options present Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0611362, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0585177, No Iterations 2 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib64/libpthread.so.0 #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #7 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:? #8 ? at ??:? #9 __libc_start_main in /lib64/libc.so.6 #10 ? at ??:? Regards, Syavash |
Bruno Santos
Quick answer: I remember seeing this problem in the past and I have a very vague memory that the issue was due to a compiler version problem...
Questions:
#5 | |
Syavash Asgari
Thanks Bruno, I guess we are in the right track. In response to your questions: 1-The distribution is CentOS 7. 2-I have used Intel compiler/2018a-eb to compile the foam. 3-Yes! I have added the following flags to the "c++" file under 'wmake/rules/linux64Icc': Code:
-Nmpi -Nmkl -xCORE-AVX512 Non-root installation of OpenFOAM 2.4.x, parallel issue The other flags I added were recommended by HPC webpage. I had included them also in foam-2.3.1 installation but it was fine there! 4-Well, I have provided the alias I use to call foam 1906 below. There are some other modules but I cannot say that they use compiler options (honestly not sure!). Code:
alias OF19='export FOAM_INST_DIR=/.../.../.../.../Ehsan ; module load buildenv-intel/2018a-eb; module load ParaView/5.4.1-nsc1-gcc-2018a-eb; module load HDF5/1.8.19-nsc1-intel-2018a-eb; export MPI_ROOT=$I_MPI_ROOT; source /.../.../.../.../Ehsan/OpenFOAM-v1906/etc/bashrc WM_NCOMPPROCS=4 WM_COMPILER=Icc WM_MPLIB=INTELMPI' Regards, Syavash |
Bruno Santos
Quick answers:
#7 | |
Syavash Asgari
I will recompile foam without those two flags and then report back! Regards, Syavash |
#8 | |
Syavash Asgari
Thanks to your help, the issue resolved! I removed those flags and compiled foam from scratch. Now, GAMG works. Regards, Syavash |
parallel run is slower than serial run (pimpleFoam) !!! | mechy | OpenFOAM | 18 | August 17, 2016 17:19 |
Wrong fluctuation of pressure in transient simulation | caitao | OpenFOAM Running, Solving & CFD | 2 | March 5, 2015 21:33 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
