[OpenFOAM.org] Start-Up Error of ParaView (after installation from ThridParty-dev)
Old   November 28, 2019, 11:26
Default Start-Up Error of ParaView (after installation from ThridParty-dev)
Yannick Pfisterer
Yannick6247 is on a distinguished road
Hey everyone!
I had to switch my OpenFOAM-7 version to OpenFOAM-dev(from GitHub) in order to be able to use the new comfort-functionObject.
After I got OpenFOAM-dev successfully to run, I was not able to start-up ParaView anymore. After troubleshooting and trying several different methods to install and compile ThirdParty-dev and OpenFOAM-dev, I was still not able to run ParaView. OpenFOAM-dev, on the other hand, is working just fine.
Lastly, I followed all instructions from this guide:
https://openfoamwiki.net/index.php/I...u#Ubuntu_18.04
Although ParaView was successfully installed, using the command
./makeParaView -python -mpi -python-lib /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 > log.makePV 2>&1
Paraview shows a black screen at startup. (typing "paraview" in the terminal)
Evaluating the log-file gives me this error message:
Version information
    qt        5.9.5
    version   5.6.0
    major     5.6
    build     Release
MISMATCH!
    specified 5.6.0
    found
I am using VNC Viewer(from my Windows10-laptop) to access the Ubuntu device for my simulation.
I am using Ubuntu 18.04.3 LTS bionic (No LSB modules are available).
"uname -m" shows "x86_64".
Using the above Installation Guide above for point 9.1, I only changed
cd $WM_THIRD_PARTY_DIR export QT_SELECT=qt4
to
cd $WM_THIRD_PARTY_DIR export QT_SELECT=qt5
Also, attached please find my log-file alongside this thread.
As the whole log file was too big, I chose to delete several lines in between(is marked).
log.makePV.txt
Does anybody have any ideas what might be causing ParaView to stop working like that?
I would very much appretiate your help!
Yannick6247 is offline   Reply With Quote
[OpenFOAM] Installation of ParaView on Ubuntu that exists in (Windows Subsystem Linux) k.farnagh ParaView 8 November 20, 2023 09:40
[OpenFOAM.com] Ubuntu 16.04 OpenFOAM-v1706 ParaView Installation Error kaszt OpenFOAM Installation 4 August 25, 2017 18:01
Installation Problem with ParaView 3.12.0 on Scientific Linux 5.7 Wley OpenFOAM Installation 2 September 28, 2012 06:06
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
