[OpenFOAM.org] Cannot open configuration file mpicc-wrapper-data.txt mpicc: Not found
Old   November 25, 2019, 09:01
Default Cannot open configuration file mpicc-wrapper-data.txt mpicc: Not found
Wenjun Tuan
wenjuny is on a distinguished road
Dear all,
i am installing openfoam6 on RHEL 6.10 without root. i have followed the instructions on https://openfoamwiki.net/.
However, at step 15, Given that a custom Open-MPI version is being built with these instructions, it's necessary to first build it before ParaView so that Open-MPI can be used by ParaView:
cd $WM_THIRD_PARTY_DIR
./Allwmake > log.make 2>&1
wmRefresh
I encountered a problem. it always reported "Cannot open configuration file .....mpicc-wrapper-data.txt" "mpicc: Not found".
I have attached the log.make file as follows, could anyone help me to solve this problem?
as follows
Cannot open configuration file /home/users/................/OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/openmpi-2.1.1/share/openmpi/mpicc-wrapper-data.txt
Error parsing data file mpicc: Not found
make[2]: *** [bdgraph_bipart_ml.o] Error 243
make[2]: *** Waiting for unfinished jobs....
Cannot open configuration file /home/users/............./OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/openmpi-2.1.1/share/openmpi/mpicc-wrapper-data.txt
make[2]: *** [bdgraph_bipart_bd.o] Error 243
Cannot open configuration file /home/users/............../OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/openmpi-2.1.1/share/openmpi/mpicc-wrapper-data.txt
Cannot open configuration file /home/users/............/OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/openmpi-2.1.1/share/openmpi/mpicc-wrapper-data.txt
Cannot open configuration file /home/users/.............../OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/openmpi-2.1.1/share/openmpi/mpicc-wrapper-data.txt
make[2]: *** [ptdummysizes] Error 243
make[2]: *** [bdgraph.o] Error 243
make[2]: *** [bdgraph_bipart_df.o] Error 243
make[2]: *** [bdgraph_bipart_ex.o] Error 243
make[2]: *** [bdgraph_bipart_sq.o] Error 243
make[2]: *** [bdgraph_bipart_st.o] Error 243
make[2]: Leaving directory `/home/users/............../OpenFOAM/ThirdParty-6/scotch_6.0.6/src/libscotch'
make[1]: *** [ptscotch] Error 2
make[1]: Leaving directory `/home/users/.............../OpenFOAM/ThirdParty-6/scotch_6.0.6/src/libscotch'
make: *** [libptscotch] Error 2
+ make realclean
(cd libscotch ; make realclean)
make[1]: Entering directory `/home/users/............/OpenFOAM/ThirdParty-6/scotch_6.0.6/src/libscotch'
rm -f *~ *.o lib*.so parser_yy.c parser_ly.h parser_ll.c *scotch.h *scotchf.h y.output *dummysizes
make[1]: Leaving directory `/home/users/................./OpenFOAM/ThirdParty-6/scotch_6.0.6/src/libscotch'
(cd scotch ; make realclean)
make[1]: Entering directory `/home/users/............./OpenFOAM/ThirdParty-6/scotch_6.0.6/src/scotch'
rm -f *~ *.o acpl amk_ccc amk_fft2 amk_grf amk_hy amk_m2 amk_p2 atst gbase gcv *ggath *gmap gmk_hy gmk_m2 gmk_m3 gmk_msh gmk_ub2 gmtst *gord gotst gout *gpart *gscat *gtst mcv mmk_m2 mmk_m3 mord mtst
make[1]: Leaving directory `/home/users/............../OpenFOAM/ThirdParty-6/scotch_6.0.6/src/scotch'
(cd libscotchmetis ; make realclean)
make[1]: Entering directory `/home/users/............./OpenFOAM/ThirdParty-6/scotch_6.0.6/src/libscotchmetis'
rm -f *~ *.o lib*.so metis.h parmetis.h
make[1]: Leaving directory `/home/users/............../OpenFOAM/ThirdParty-6/scotch_6.0.6/src/libscotchmetis'
(cd check ; make realclean)
make[1]: Entering directory `/home/users/............../OpenFOAM/ThirdParty-6/scotch_6.0.6/src/check'
rm -f *~ *.o
rm -f \
test_common_file_compress \
test_common_random \
test_common_thread \
test_fibo \
test_scotch_arch \
test_scotch_arch_deco \
test_scotch_graph_coarsen \
test_scotch_graph_color \
test_scotch_graph_diam \
test_scotch_graph_map \
test_scotch_graph_map_copy \
test_scotch_graph_order \
test_scotch_graph_part_ovl \
test_scotch_dgraph_band \
test_scotch_dgraph_check \
test_scotch_dgraph_coarsen \
test_scotch_dgraph_grow \
test_scotch_dgraph_redist \
test_scotch_mesh_graph \
test_strat_par \
test_strat_seq
make[1]: Leaving directory `/home/users/............/OpenFOAM/ThirdParty-6/scotch_6.0.6/src/check'
(cd esmumps ; make realclean)
make[1]: Entering directory `/home/users/......./OpenFOAM/ThirdParty-6/scotch_6.0.6/src/esmumps'
rm -f *~ common.h *.o lib*.so main_esmumps
make[1]: Leaving directory `/home/users/......./OpenFOAM/ThirdParty-6/scotch_6.0.6/src/esmumps'
rm -f ../bin/* ../include/* ../lib/*
WARNING: required include file 'ptscotch.h' not found!
Build Metis decomposition
optional component Metis was not found
Build CGAL
CGAL headers in /home/users......./OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/CGAL-4.10/include
CGAL libs in /home/users......./OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/CGAL-4.10/lib64
Done ThirdParty Allwmake
wenjuny is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
