[OpenFOAM.org] Cannot open configuration file mpicc-wrapper-data.txt mpicc: Not found |
November 25, 2019, 09:01 |
Wenjun Tuan
Rep Power: 8 |
Dear all,
i am installing openfoam6 on RHEL 6.10 without root. i have followed the instructions on https://openfoamwiki.net/. However, at step 15, Given that a custom Open-MPI version is being built with these instructions, it's necessary to first build it before ParaView so that Open-MPI can be used by ParaView: cd $WM_THIRD_PARTY_DIR ./Allwmake > log.make 2>&1 wmRefresh I encountered a problem. it always reported "Cannot open configuration file .....mpicc-wrapper-data.txt" "mpicc: Not found". I have attached the log.make file as follows, could anyone help me to solve this problem? as follows Cannot open configuration file /home/users/................/OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/openmpi-2.1.1/share/openmpi/mpicc-wrapper-data.txt Error parsing data file mpicc: Not found make[2]: *** [bdgraph_bipart_ml.o] Error 243 make[2]: *** Waiting for unfinished jobs.... Cannot open configuration file /home/users/............./OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/openmpi-2.1.1/share/openmpi/mpicc-wrapper-data.txt Error parsing data file mpicc: Not found make[2]: *** [bdgraph_bipart_bd.o] Error 243 Cannot open configuration file /home/users/............../OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/openmpi-2.1.1/share/openmpi/mpicc-wrapper-data.txt Cannot open configuration file /home/users/............/OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/openmpi-2.1.1/share/openmpi/mpicc-wrapper-data.txt Error parsing data file mpicc: Not found Cannot open configuration file /home/users/.............../OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/openmpi-2.1.1/share/openmpi/mpicc-wrapper-data.txt Error parsing data file mpicc: Not found Error parsing data file mpicc: Not found Cannot open configuration file /home/users/................/OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/openmpi-2.1.1/share/openmpi/mpicc-wrapper-data.txt Error parsing data file mpicc: Not found make[2]: *** [ptdummysizes] Error 243 make[2]: *** [bdgraph.o] Error 243 make[2]: *** [bdgraph_bipart_df.o] Error 243 make[2]: *** [bdgraph_bipart_ex.o] Error 243 Cannot open configuration file /home/users/............../OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/openmpi-2.1.1/share/openmpi/mpicc-wrapper-data.txt Error parsing data file mpicc: Not found Cannot open configuration file /home/users/............./OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/openmpi-2.1.1/share/openmpi/mpicc-wrapper-data.txt Error parsing data file mpicc: Not found make[2]: *** [bdgraph_bipart_sq.o] Error 243 make[2]: *** [bdgraph_bipart_st.o] Error 243 make[2]: Leaving directory `/home/users/............../OpenFOAM/ThirdParty-6/scotch_6.0.6/src/libscotch' make[1]: *** [ptscotch] Error 2 make[1]: Leaving directory `/home/users/.............../OpenFOAM/ThirdParty-6/scotch_6.0.6/src/libscotch' make: *** [libptscotch] Error 2 + make realclean (cd libscotch ; make realclean) make[1]: Entering directory `/home/users/............/OpenFOAM/ThirdParty-6/scotch_6.0.6/src/libscotch' rm -f *~ *.o lib*.so parser_yy.c parser_ly.h parser_ll.c *scotch.h *scotchf.h y.output *dummysizes make[1]: Leaving directory `/home/users/................./OpenFOAM/ThirdParty-6/scotch_6.0.6/src/libscotch' (cd scotch ; make realclean) make[1]: Entering directory `/home/users/............./OpenFOAM/ThirdParty-6/scotch_6.0.6/src/scotch' rm -f *~ *.o acpl amk_ccc amk_fft2 amk_grf amk_hy amk_m2 amk_p2 atst gbase gcv *ggath *gmap gmk_hy gmk_m2 gmk_m3 gmk_msh gmk_ub2 gmtst *gord gotst gout *gpart *gscat *gtst mcv mmk_m2 mmk_m3 mord mtst make[1]: Leaving directory `/home/users/............../OpenFOAM/ThirdParty-6/scotch_6.0.6/src/scotch' (cd libscotchmetis ; make realclean) make[1]: Entering directory `/home/users/............./OpenFOAM/ThirdParty-6/scotch_6.0.6/src/libscotchmetis' rm -f *~ *.o lib*.so metis.h parmetis.h make[1]: Leaving directory `/home/users/............../OpenFOAM/ThirdParty-6/scotch_6.0.6/src/libscotchmetis' (cd check ; make realclean) make[1]: Entering directory `/home/users/............../OpenFOAM/ThirdParty-6/scotch_6.0.6/src/check' rm -f *~ *.o rm -f \ test_common_file_compress \ test_common_random \ test_common_thread \ test_fibo \ test_scotch_arch \ test_scotch_arch_deco \ test_scotch_graph_coarsen \ test_scotch_graph_color \ test_scotch_graph_diam \ test_scotch_graph_map \ test_scotch_graph_map_copy \ test_scotch_graph_order \ test_scotch_graph_part_ovl \ test_scotch_dgraph_band \ test_scotch_dgraph_check \ test_scotch_dgraph_coarsen \ test_scotch_dgraph_grow \ test_scotch_dgraph_redist \ test_scotch_mesh_graph \ test_strat_par \ test_strat_seq make[1]: Leaving directory `/home/users/............/OpenFOAM/ThirdParty-6/scotch_6.0.6/src/check' (cd esmumps ; make realclean) make[1]: Entering directory `/home/users/......./OpenFOAM/ThirdParty-6/scotch_6.0.6/src/esmumps' rm -f *~ common.h *.o lib*.so main_esmumps make[1]: Leaving directory `/home/users/......./OpenFOAM/ThirdParty-6/scotch_6.0.6/src/esmumps' rm -f ../bin/* ../include/* ../lib/* WARNING: required include file 'ptscotch.h' not found! ======================================== Build Metis decomposition optional component Metis was not found ======================================== Build CGAL CGAL headers in /home/users......./OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/CGAL-4.10/include CGAL libs in /home/users......./OpenFOAM/ThirdParty-6/platforms/linux64Gcc48/CGAL-4.10/lib64 ======================================== Done ThirdParty Allwmake |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
