[OpenFOAM.org] ELI5: use a different compiler when compiling from source
Old   April 7, 2020, 06:29
Default ELI5: use a different compiler when compiling from source
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Hi, I managed to compile a working OpenFOAM v7 version from source. However, I guess that the default gcc compiler (7.5) on my system was used while doing so.
I have a newer version of gnu compilers (9.2) installed on my system, accessible via gcc-9. Which changes do I need to make in order to use this newer version during compilation?
flotus1 is offline   Reply With Quote
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 03:50
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 15:14
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
