[OpenFOAM.com] ThirdParty Build errors
Old   August 7, 2020, 05:54
Unhappy ThirdParty Build errors
Pham Tran Quang Huy
ptqhuy is on a distinguished road
Hello there,
Yesterday I finished compiling OpenFOAM+ v2006, and I'm sure I did successfully as the "post-compilation steps" went smoothly, follow this instructions https://develop.openfoam.com/Develop...p/doc/Build.md
But when I moved to ThirdParty according to https://develop.openfoam.com/Develop...velop/BUILD.md, it went complex:
_ first,
 ./makeFFTW -help
showed
 Error (makeFFTW) : not located in $WM_THIRD_PARTY_DIR
      Check your OpenFOAM environment and installation
_then,
 which mpicc
lead to
 /usr/bin/which: no mpicc in (/home/username/simFlow/simFlow-4.0:
/home/username/anaconda3/bin:
/home/username/anaconda3/condabin:
/home/username/.local/bin:
/home/username/bin:
/usr/lib64/ccache:
/usr/local/bin:
/usr/bin:
/bin:
/usr/local/sbin:
/usr/sbin:
/usr/lib64/mpi/gcc/openmpi/bin:
/home/username/basilisk/src:
/home/username/basilisk/src)
I have no clue why this happened because I installed openmpi peacefully. (This alert was a straight line, I splitted them to rows for easy to see)
_ for "Adjust the etc/bashrc, etc/config.sh/...", I tried to look at them but seeing nothing to adjust.
_these commands "./makeGcc" "./makeLLVM" "./makeCMake" all lead to
 Error (command_name) : not located in $WM_THIRD_PARTY_DIR
_finally "./Allmake" command also has the same result.
So I think the problem is something in "not located in $WM_THIRD_PARTY_DIR
Check your OpenFOAM environment and installation"
but I don't have a clue to solve it, I tried to find $WM_THIRD_PARTY_DIR in /OpenFOAM/OpenFOAM-v2006/etc/bashrc and some files recommended as above but seeing no where to change the value.
Before asking there, I have re-compiled the whole program because I thought the problem is changing directory (I compiled OF in a dir, then moved them to another dir, it still run "post-compilation steps" smoothly so that's not the reason). Now the problem is stand still, I have to change some values, I guess.
//ehh, by the way, I find the ThirdParty guide is not as explicit as the Main guide.
I use Fedora 32 if that helps.
ptqhuy is offline   Reply With Quote
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 09:10
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
