[OpenFOAM.com] make Installation for MacOS
Old   February 10, 2021, 12:18
Default make Installation for MacOS
Kim Best
KimBest is on a distinguished road
Hi I'm new to openFoam and coding with bash in general and I've run into some problems running the case tutorials which use code streams to compile. When I use ./Allrun on these cases, I get the error:
No wmake command found ... cannot compile
I installed make using homebrew (by simply putting brew install make into the command window) but this hasn't made a difference and openFoam doesn't seem to recognise I've installed make for it to run wmake. I'm wondering if anyone might be able to give me a bit of help with this as I've been trying to solve this for quite a few days now and havn't got anywhere. To be honest I think this is because I'm pretty out of my depth with some of the bash knowledge so it's quite hard for me to understand what I need to do. I think it has something to do with make not being fully installed for some reason? Or maybe because I need to move the make folder to a specific location? Any help would really really be appreciated for this newbie!
By the way, I installed openfoam with docker and am running on macOs 10.14.6
KimBest is offline   Reply With Quote
Old   February 10, 2021, 15:24
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Would you consider to dive into the build wiki for the installation?
Did you ensure that your installation is complete? Please check your installation by running foamInstallationTest.
Did you source OpenFOAM environment before executing "./Allrun" which contains OpenFOAM commands?
HPE is offline   Reply With Quote
Old   February 11, 2021, 08:24
Kim Best
I didn't use the wiki installation as the openfoam.com website explicitly recommeds to install via docker. I implemented the instructions here relogiously (https://www.openfoam.com/download/in...binary-mac.php). It also says at the bottom that all the code should be compiled by docker, ie.
"The Docker environment contains a full OpenFOAM development environment so all Allwmake, wmake, wclean etc. commands work (it is running the actual environment OpenFOAM was compiled in!) "
, and: " mounts the home directory of the user with read/write access
optionally channels the graphics
sets up the OpenFOAM environment.
When I run foamInstallationTest in terminal, it tells me I am missing ThirdParty, and that wmake is uninstalled. It also says: [env variable unset] next to $WM_DIR . Do you think there is a way for me to sort this issue while continuing with Docker, as I suspect if i go down the wiki installation way I will create more errors for myself.
I have also installed the mac command line tools so I would have thought docker would be able to compile wmake from them.
Old   February 26, 2021, 11:41
Default An updated installation guide
Büşra Çetin
bushra is on a distinguished road
I too lost among several installation guides. Firstly i installed Docker then removed due to advices about installation from source.
Secondly, with the aid of an obsolete guide (but it became life-saver), i installed macports and paraview. For OF installation, i cloned foam-extend-4. Then step of "edit the bashrc" did not work. The default shell is neither bash nor csh, it's zsh. Should I install the bash shell?
Could anyone make it clear?
Bushra
bushra is offline   Reply With Quote
Old   March 3, 2021, 09:49
Kim Best
Originally Posted by bushra View Post
Bushra
Hi Bushra,
Did you manage to do the installation successfully? I am still using the docker installation but I don't want to begin with installing from source unless I know it can definitely work properly.
Kim
Old   March 4, 2021, 15:52
Büşra Çetin
Originally Posted by KimBest View Post
Hi Bushra,
Kim
No Kim, I could not install yet. I agree with you, continue with docker.
Old   March 5, 2021, 05:26
Kim Best
Okay thanks for the update. I think with docker most of the functionality is retained and it's only a few specific things which don't work, namely cases using codestreams and the fvOptions utility (which is what I'm trying to sort now).
Old   March 6, 2021, 03:41
Büşra Çetin
I thank you too.
Since I have any more time to start CFD analysis, I'm trying to install from source. The problem may be caused by the shell of terminal that's zsh for me, while guides explain steps with bash.
Old   March 6, 2021, 06:39
Kim Best
I thank you too.
I see. I think now instead I am going to pursue running OF with amazon web services via remote desktop instead, as I think that will be more error free.
I have now switched to using CFDDFC on amazon's web services to run my simulations. I can confirm that there is something wrong with the mac installation files, as I can now run the simulations perfectly with my chosen geometry.
Kim
Two phase flow in porous medium Milaad OpenFOAM 6 December 15, 2020 07:55
macOSX installation issues fulcrum64th SU2 Installation 2 May 29, 2019 12:14
fireFoam installation Roman1 OpenFOAM Installation 2 September 27, 2013 03:05
compiling firefoam Farshad_Noravesh OpenFOAM 27 December 24, 2012 04:21
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
