[OpenFOAM.org] Need help with compilation of firefoamdev or firefoam 2.2.x |
February 27, 2021, 12:19 |
How to complie firefoamdev or firefoam 2.2.x correctly with OpenFOAMdev or OpenFoam.
Janeshwar Sharma
Rep Power: 5 |
I am working on Project "Fire Swirls simulation" and for that I need to use firefoamdev or firefoam2.2.x. developed by FM Global I tried to compile fireform dev with Open Foam dev on ubuntu 16.04 using this reference - https://github.com/FireRiskAlliance/firefoam-install I tried from this reference a lot of times but failed every time. After this I tried to compile firefoam2.2.x with openfoam2.2.2 on ubuntu 18.04(compiled from this link - https://openfoamwiki.net/index.php/I...u#Ubuntu_18.04) but again failed . The error logfile during this compilation is attached . I am stuck with this from along and I need to complete this project soon. Contact - janeshwar09@gmail.com Any help is appreciated. Last edited by Janeshwar; February 28, 2021 at 12:34. Reason: Title can be more precise. |
February 28, 2021, 11:42 |
Mark Olesen
Rep Power: 40 |
If you use fireFoam from OpenFOAM-v2012 (Dec 2020 release) it should have everything that your referenced repo from 2017 has.
For Ubuntu, you can use the precompiled packages https://develop.openfoam.com/Develop...ompiled/debian |
firefoam;installation, openfoam installation |
fireFoam in OF 2.2.x | babakflame | OpenFOAM Running, Solving & CFD | 1 | December 27, 2013 06:21 |
fireFoam installation | Roman1 | OpenFOAM Installation | 2 | September 27, 2013 03:05 |
How to setup a proper "heatFlux" boundary for fireFoam? | Jumping | OpenFOAM Pre-Processing | 0 | March 27, 2013 09:27 |
Compilation Error (V 1.7.1; Icc 12.1.0, OpenMPI 1.4.3) | floydfan | OpenFOAM Installation | 7 | December 20, 2011 05:56 |
Compilation Error.... | Arnab | Siemens | 4 | September 12, 2004 15:54 |
