[foam-extend.org] Foam-Extend 4.0 cannot load parmetis, metis and scotch decomp on Manjaro
Old   May 17, 2021, 06:20
Default Foam-Extend 4.0 cannot load parmetis, metis and scotch decomp on Manjaro
Sultan Islam
EternalSeekerX is on a distinguished road
Hello everyone
I am trying to build and run foam extend 4.0 on either of my linux vm installs. Currently working in manjaro. I build fe40 using gcc-49 and make sure to point to third party rpm functions. I am also using system mpi. Now the build is successful and shows no errors at all. However when I try to run tutorials like axial_gg I get errors about not being able to loadmetis, scotch or parmetis decomposition. Heirchy and simple decomp work fine. However the others do not...is this due to system mpi being to new ? Or is there something else I need to do? I'm just tempted to just run foam extend in a docker if it can't be run on manjaro, howver if I am missing something do let me know.
EternalSeekerX is offline   Reply With Quote
