[OpenFOAM.com] paraview for openfoam
Old   June 7, 2022, 09:08
Default paraview for openfoam
vesvard
dim14 is on a distinguished road
Hello, i have installed openfoam and i'm trying to work on a tutorial. All is working perfectly, except the command paraFoam which can not launch paraview:
invalid $pv_PLUGIN_PATH and -plugin-path= not defined
I'm using unbutu and have installed openfoam2112 and paraview5.0 in the same repertory usr/lib/openfoam/
dim14 is offline   Reply With Quote
Old   June 7, 2022, 09:58
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
https://discourse.paraview.org/t/i-w...uld-i-use/7232
olesen is offline   Reply With Quote
Old   June 7, 2022, 10:21
vesvard
Thanks for the answer; But i'm not sure that i have understood : i should use paraFoam -vtk command, When i try i obtain this message :
dimitri@dimitri-ThinkPad-X250:~/OpenFOAM/dimitri-8/run/preGeo$ paraFoam -vtk
Created temporary 'preGeo.foam'
/usr/lib/openfoam/openfoam2112/bin/paraFoam: 423: paraview: not found
Old   June 7, 2022, 14:11
Mark Olesen
apt-get install paraview?
Old   June 7, 2022, 15:03
vesvard
Oups, You're right. Thanks a lot
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release FJSJ OpenFOAM Installation 2 July 23, 2017 05:48
Paraview version update errors Dan Pearce OpenFOAM Installation 5 January 8, 2014 05:47
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 13:24
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? lentschi OpenFOAM Installation 1 March 9, 2011 02:32
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
