June 7, 2022, 09:08 |
paraview for openfoam
vesvard
Rep Power: 3 |
Hello, i have installed openfoam and i'm trying to work on a tutorial. All is working perfectly, except the command paraFoam which can not launch paraview:
invalid $pv_PLUGIN_PATH and -plugin-path= not defined I'm using unbutu and have installed openfoam2112 and paraview5.0 in the same repertory usr/lib/openfoam/ |
June 7, 2022, 09:58 |
Mark Olesen
Rep Power: 40 |
June 7, 2022, 10:21 |
vesvard
Rep Power: 3 |
Thanks for the answer; But i'm not sure that i have understood : i should use paraFoam -vtk command, When i try i obtain this message :
dimitri@dimitri-ThinkPad-X250:~/OpenFOAM/dimitri-8/run/preGeo$ paraFoam -vtk Created temporary 'preGeo.foam' /usr/lib/openfoam/openfoam2112/bin/paraFoam: 423: paraview: not found |
June 7, 2022, 14:11 |
Mark Olesen
Rep Power: 40 |
apt-get install paraview?
June 7, 2022, 15:03 |
vesvard
Rep Power: 3 |
Oups, You're right. Thanks a lot
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release | FJSJ | OpenFOAM Installation | 2 | July 23, 2017 05:48 |
Paraview version update errors | Dan Pearce | OpenFOAM Installation | 5 | January 8, 2014 05:47 |
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) | chrisb2244 | OpenFOAM Installation | 2 | August 21, 2013 13:24 |
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? | lentschi | OpenFOAM Installation | 1 | March 9, 2011 02:32 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
