[OpenFOAM.org] Update the OpenFoam version
Old   August 8, 2023, 08:41
Default Update the OpenFoam version
sarina is on a distinguished road
Dear all,
I have some problems with the installed openfoam version (number 8). How I can update it? Do you suggest to remove it and then install a new version?
Thanks!
sarina is offline   Reply With Quote
Old   August 9, 2023, 03:15
Roland
sylvester is on a distinguished road
You do not have to delete an old version. You can easily install a new version and continue using both. You can delete the old version if you no longer require it. Upgrading from one version to another is not possible.
sylvester is offline   Reply With Quote
what is problem my OpenFoam setting? Lee97 Main CFD Forum 0 September 1, 2022 08:57
Inaccurate results for some turbulent annular flows using K-Omega SST donree4 OpenFOAM Running, Solving & CFD 1 March 19, 2019 18:15
simpleFoam convergence issue Harnoor OpenFOAM Running, Solving & CFD 13 November 16, 2016 08:23
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 03:18
OpenFOAM-1.6 install cookbook MadsR OpenFOAM Installation 372 November 20, 2010 11:57
