cannot cannot find qmake either at $QMAKE_PATH or in current $PATH
Old   February 13, 2014, 11:10
Default cannot cannot find qmake either at $QMAKE_PATH or in current $PATH
Kai Liang
ljjouc is on a distinguished road
Hi,everyone:
I am trying to install openfoam2.2.2 in OpenSUSE 13.1. After I correctly build the sources, I execute the following code to install paraview,
cd $WM_THIRD_PARTY_DIR
./makeParaView
but,the error " cannot find qmake either at $QMAKE_PATH or in current $PATH" occurs.
Does anyone kindly help me to solve this problem? I am looking forward to your reply.
ljjouc is offline   Reply With Quote
Old   February 16, 2014, 10:46
Retired Super Moderator
Bruno Santos
Greetings Kai,
Which installation instructions are you following?
Have you tried following these instructions: http://openfoamwiki.net/index.php/In...#openSUSE_12.3
Best regards,
Bruno
Old   February 17, 2014, 10:04
Kai Liang
I am very appreciated for your help. The problem has been solved and the reason is that qmake is not installed. After all, the website you afford is very usefull and of great value.
Best wishes.
Old   August 15, 2023, 23:34
Jimmy Wang is on a distinguished road
Greetings Kai
I have the same problem. So how do you install qmake. I've tried yum install qt5 qt5-devel. But it didn't work for me.
Best regards,
Jimmy
Best wishes.
Jimmy Wang is offline   Reply With Quote
[OpenFOAM.org] Error: cannot find qmake either at $QMAKE_PATH or in current $PATH achinta OpenFOAM Installation 6 June 8, 2012 17:37
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 00:52
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 06:32
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
