[OpenFOAM.com] Possible $PATH issue in V2212 windows mingw installation
Old   June 21, 2023, 16:16
Default Possible $PATH issue in V2212 windows mingw installation
Scott Stevenson
sstevenson638 is on a distinguished road
I'm trying to get the cfdOF package in FreeCAD working. The recommended OpenFOAM install is the Windows mingw package, specifically version 2206.
I installed the latest 2212 version thinking the newer version should work. I also installed cfmesh and HISA. Unfortanately cfdOF cannot find either cfmesh or HISA to execute those commands externally. Thinking it might be a PATH issue with the external environment I executed the openfoam terminal command to check the environment $PATH variable.
OpenFOAM-v2212-MSYS2-Terminal
When I type $PATH I get the following output:
$ $PATH
bash: /home/ofuser/OpenFOAM/sstev-v2212/platforms/win64MingwDPInt32Opt/bin:/home/ofuser/OpenFOAM/OpenFOAM-v2212/site/2212/platforms/win64MingwDPInt32Opt/bin:/home/ofuser/OpenFOAM/OpenFOAM-v2212/platforms/win64MingwDPInt32Opt/bin:/home/ofuser/OpenFOAM/OpenFOAM-v2212/bin:/usr/local/bin:/usr/bin:/bin:/opt/bin:/c/Program: No such file or directory
Notice the last entry in the list "/c/Program: No such file or directory"
Looking at the source, I think the script responsible for creating the environment $PATH is
setEnvVariables-v2212.bat
The last line in this script is:
set PATH=%WM_PROJECT_DIR%\platforms\%TYPE%\bin\;%WM_PR OJECT_DIR%\platforms\%TYPE%\lib\mpi\;%WM_THIRD_PAR TY_DIR%\platforms\%TYPE_THIRDPARTY%\lib\;%PATH%
You can see the last term "%PATH%" where it is applying the windows path. This is apparently not working. Can anyone help? How to I get all the needed PATH information into the OpenFOAM terminal environment?
Thanks in advance.
sstevenson638 is offline   Reply With Quote
Old   June 21, 2023, 23:05
Default Nevermind
Scott Stevenson
I'm not sure what the problem was but the PATH issue cleared itself up the next time I worked in this issue. I still cannot get cfdOF to recognize cfmesh, gmesh, or hisa, but that is a separate problem that I continue to work on.
[OpenFOAM] Installation ParaView for Windows version of openFOAM kasra karimi ParaView 14 September 8, 2018 14:06
SU2 Installation on Windows 32 bit niddaas SU2 Installation 3 May 6, 2016 17:03
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
nmake issue with Windows sega FLUENT 19 June 16, 2010 01:16
divide by zero FPE issue in OpenFOAM 141 MingW port allenzhao OpenFOAM Installation 9 September 22, 2008 17:13
