[OpenFOAM.com] paraFoam command not working to view mesh
Old   September 11, 2023, 22:10
Default paraFoam command not working to view mesh
Madhu
RavenWorks is on a distinguished road
Hello, I've only recently downloaded OpenFoam in the past few days and have made a mesh of an object but im unable to view it in paraView. When i enter paraFoam in the command window, i get the following.
'paraFoam' is not recognized as an internal or external command,
operable program or batch file.
I tried messing around with the bashrc file but I really don't know what I'm doing. Im on Windows 11 trying to run paraview 5.11.1. Any help would be appreciated.
Thanks!
RavenWorks is offline   Reply With Quote
Old   September 19, 2023, 11:47
Shenhui Ruan
fly_light is on a distinguished road
Hello Madhu,
Please tell us more information about your installation.
As far as I know now. you are using OpenFOAM with WSL now.
If you want to run the command
parafoam
, you need to compile the Paraview in the "ThirdParty" folder. In fact, I do not suggest you to do this.
You can install the Paraview in Windows.
And then run command
explorer.exe .
to open your case folder in windows explore. You need to create a file name xxx.foam, e.g. test.foam,, and drag it to the paraview window.
Best regards.
fly_light is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 12:38
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
