Wmake C and KDevelop for a Foam project
Old   September 20, 2005, 20:54
Default Hi folks, has anyone tried
Ron W Cresswell
roncresswell is on a distinguished road
Hi folks,
has anyone tried to set up and use KDevelop under linux to manage a Foam project? I was wondering how good it is and whether I should consider it?
Ron
roncresswell is offline   Reply With Quote
Old   January 1, 2008, 07:35
Default Hi there, Interesting idea
Yingfeng Shen
yingfeng is on a distinguished road
Hi there,
Interesting idea for me too since I am using kdevelop 3.5.0 recently, and I really enjoyed the nice editor. A simple procedure I found is:
1. assume the project is already sitting under a folder and can be compiled with wmake
2. create a script named foamK
. /home/yshen/OpenFOAM/OpenFOAM-1.4.1-dev/wmake/wmake
kdevelop
the first line sets up OpenFoam environment, the second line starts kdevelop
chmod a+x foamK
copy foamK to /usr/local/bin
3. run foamK to start kdevelop.
4. go to Project -> Importing existing project to add all the files
5. under Project -> Project Options, choose Build Options->Other, set the name of build script to
/home/username/OpenFOAM/OpenFOAM-1.4.1-dev/wmake/wmake, you can find your path by typing 'which wmake' in your terminal
6. you would need to add '-DFULLDEBUG -g -O0' to your Make/option file in order to debug the executable in kdevelop
happy new year!
Yingfeng
yingfeng is offline   Reply With Quote
Old   January 1, 2008, 14:44
Default If you're looking for alternat
Sandeep Menon
deepsterblue will become famous soon enough
If you're looking for alternatives, I'd suggest NetBeans. I've configured it with OpenFOAM, and the procedure is descibed here:
http://openfoamwiki.net/index.php/Configure_NetBeans
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   January 3, 2008, 14:52
Default Dear Sandeep, tried NetBean
sradl's Avatar
Stefan Radl
sradl is on a distinguished road
Dear Sandeep,
tried NetBeans, however it does not work with OF 1.4. It tells me that it could not find the Make directory (needed by wmake)!
How does NetBeans know where the Make directory is?
sradl is offline   Reply With Quote
Old   January 3, 2008, 15:25
Default It does work. I'm using it rig
Sandeep Menon
It does work. I'm using it right now.
All that you're doing here is modifying NetBeans to call (the modified) wmake, which requires the Make directory (instead of gmake, which Netbeans assumes by default).
Could you post your output?
Sandeep Menon
Old   January 4, 2008, 03:47
Default Hi Sandeep, problem solved,
sradl's Avatar
Stefan Radl
Hi Sandeep,
problem solved, I just had to direct netBean to the correct source directory.
Thanks in advance
Old   January 4, 2008, 06:05
Default Dear Sandeep, although I'm
sradl's Avatar
Stefan Radl
Dear Sandeep,
although I'm starting to like netBeans, I have a problem:
when I navigate to an include-file that lives anywhere else (e.g. fvCFD.H), there are some include statements (e.g. Time.H) that are underlined in red, i.e., they are not sourced correctly. Only *.H files in the same directory as the sourced file fvCFD.H are not underlined. However, I'm sure that they are sourced (in the Tools->Options->Code Assistance/C++Compiler-Include Directories) and I can navigate to them when they are included in the project files (e.g., when I include Time.H in the solver's C-file, I can navigate to Time.H)!
Any idea how to get rid of this so that I can navigate conveniently to sub-sourced files?
br
Stefan
Old   January 4, 2008, 11:18
Default Are you adding the lnInclude d
Sandeep Menon
Are you adding the lnInclude directories under code-assistance? You'd be able to see all the necessary headers that way...
Sandeep
Sandeep Menon
Old   January 19, 2008, 06:25
Default Hi folks, I have just install
Giovanni Caramia
karamiag is on a distinguished road
Hi folks,
I have just installed OF 1.4.1 and NetBeans 6.0, put nbmake_1.4.1 in $WM_PROJECT_DIR/wmake, changed the Make Command to the new script (as suggested in the openfoamwiki) and added all the lnInclude directories under code-assistance. Now I want to modify and compile the file
~/OpenFOAM/OpenFOAM-1.4.1/src/turbulenceModels/compressible/kEpsilon/kEpsilon.C
I start netbeans, open a new project, select C/C++ under Categories, and C/C++ Application under Projects; after this I have to provide a directory name for Project Name and Project Location. I have to provide a specific directory name and Project Location?
The problem is that right clicking kEpsilon.C and selecting "compile file", the compilation fails. The output is this
Running "rm -rf build/Release/GNU-Linux-x86/kEpsilon/kEpsilon.o" in /home/nettis/OpenFOAM/OpenFOAM-1.4.1/src/turbulenceModels/compressible
Clean successful. Exit value 0.
Running "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/wmake/nbmake_1.4.1 -f nbproject/Makefile-Release.mk build/Release/GNU-Linux-x86/kEpsilon/kEpsilon.o" in /home/nettis/OpenFOAM/OpenFOAM-1.4.1/src/turbulenceModels/compressible
g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/nettis/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/home/nettis/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -I/home/nettis/OpenFOAM/OpenFOAM-1.4.1/src/thermophysicalModels/basic/lnInclude -IlnInclude -I. -I/home/nettis/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC Make/linux64GccDPOpt/turbulenceModel.o Make/linux64GccDPOpt/newTurbulenceModel.o Make/linux64GccDPOpt/laminar.o Make/linux64GccDPOpt/kEpsilon.o Make/linux64GccDPOpt/RNGkEpsilon.o Make/linux64GccDPOpt/LaunderSharmaKE.o Make/linux64GccDPOpt/LRR.o Make/linux64GccDPOpt/LaunderGibsonRSTM.o Make/linux64GccDPOpt/realizableKE.o Make/linux64GccDPOpt/SpalartAllmaras.o Make/linux64GccDPOpt/kOmegaSST.o Make/linux64GccDPOpt/mutStandardRoughWallFunctionFvPatchScalarField.o -L/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt \
-lOpenFOAM -liberty -ldl -lm -o OpenFOAM.out
/usr/lib/../lib64/crt1.o: In function `_start':
(.text+0x20): undefined reference to `main'
Thanks,
Giovanni
karamiag is offline   Reply With Quote
Old   January 19, 2008, 11:50
Default Hi Giovanni, you are compil
Luca M.
luca is on a distinguished road
Hi Giovanni,
you are compiling your code like a standalone program instead of a library. Turbulence model is a library and the right option is wmake libso if you choose shared object libraries. Just put the option libso in the options of your development environment.
Enjoy
Luca
luca is offline   Reply With Quote
Old   January 19, 2008, 11:58
Default Well, the issue is that you're
  #11
Sandeep Menon
Well, the issue is that you're trying to compile to a shared library (.so), whereas gcc was expecting an application and therefore, a reference to main.
This is easy enough to handle - wmake (or, in this case, nbmake) is expecting an additional parameter, libso to make a shared lib. This would require a little parse-coding in the nbmake script. Or, you could live with it at the moment by typing wmake libso at the command line, each time you want to compile to a library.
Hope this helps.
Sandeep Menon
Old   January 19, 2008, 14:40
Default OK, I think I will use "wmake
  #12
Giovanni Caramia
OK, I think I will use "wmake libso" at the command line! But, is there a case in which I can make a compilation using netbeans? Can you give me an example of file/s in the src directory? If I can't compile why I have to use nbmake?
Thanks again for your patience.
Old   January 21, 2008, 12:59
Default Hi, I tried to create a kde
  #13
John Deas
johndeas is on a distinguished road
I tried to create a kdevelop project to manage my code. However, the code completion seems not to be working. I imported my application directory as a generic c++ application, then, in Project/project options/c++ support, I added
.;/home/vinz/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude;/home/vinz/OpenF OAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude;
as a custom include paths.
Am I missing something ?
Vincent
johndeas is offline   Reply With Quote
Old   January 23, 2008, 10:21
Default Giovanni, Netbeans (or any
  #14
Sandeep Menon
Giovanni,
Netbeans (or any IDE, for that matter) is just a front-end for code development. It will still rely on make/wmake/gcc for the actual compilation process. I'll admit that the nbmake script is very rudimentary, and still requires a lot of work. I use it to develop custom applications, rather than modifications to the existing libraries.
John,
I haven't tried kdevelop, but a little more specifics about the problem would be useful.
Sandeep Menon
Old   July 23, 2008, 17:52
Default I'm trying to use KDevelop 3.5
  #15
Kent S Kapitan
kent_kapitan is on a distinguished road
I'm trying to use KDevelop 3.5 for OpenFOAM-1.5 and haven't had much luck. If anyone has succesfully managed to develop openFOAM projects within KDevelop I would welcome an example of your method. For example, if I wanted to compile/link/debug the icoFoam/cavity tutorial, how would I go about importing it into KDevelop, and what Project Options should I set ? Thank you.
kent_kapitan is offline   Reply With Quote
Old   March 3, 2009, 10:02
Default thanks jiayuan jin
  #16
Jiayuan Jin
openfoam15 is on a distinguished road
thanks
jiayuan jin
openfoam15 is offline   Reply With Quote
Old   June 25, 2009, 22:28
Default kdevelop or netbean is better?
  #17
xianghong wu
wendywu is on a distinguished road
I am doing some modification to standard solvers. when the solver runs, I want to know where it has mistakes, so is kdevelop or netbean the software I can use? which one is better for OpenFOAM-1.5? are they all free software?
Thank you for any advice.
Wendy
wendywu is offline   Reply With Quote
Old   June 26, 2009, 05:28
Gunnar Werte
gunnar is on a distinguished road
none
http://lmgtfy.com/?q=netbeans
http://lmgtfy.com/?q=kdevelop
gunnar is offline   Reply With Quote
Old   June 27, 2009, 11:16
xianghong wu
Thank you.
I will try netbeans. It seems kdevelop is more complicated when downloading.
Wendy
Old   June 29, 2009, 02:30
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
My coworker uses eclipse (www.eclipse.org) with the C++ development tool (http://www.eclipse.org/cdt) and egit (http://git.or.cz/gitwiki/EclipsePlugin) the eclipse git plugin - he seems happy with the combination.
olesen is offline   Reply With Quote
Problems with wmake ivan_cozza OpenFOAM Programming & Development 14 June 30, 2013 07:34
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
Wmake problem thumthae OpenFOAM Installation 12 December 3, 2008 09:30
How should one debug a solver using KDevelop kar OpenFOAM Installation 5 July 28, 2008 16:36
Manage openfoam solver project in KDevelop probably the last linker error any suggestion is welcome lakeat OpenFOAM Installation 0 July 7, 2007 10:01
