Can someone PLEASE document the development version installation
Old   July 5, 2008, 03:44
Default Very nice! Regards, Martin
  #61
Martin Beaudoin
mbeaudoin will become famous soon enough
Very nice!
Regards,
Martin
mbeaudoin is offline   Reply With Quote
Old   July 5, 2008, 04:00
Default Amazing what can happen during
  #62
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Amazing what can happen during one night
Looks good.
- Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   July 5, 2008, 04:35
Default Great Work Alberto :-) I ha
  #63
jaswi is on a distinguished road
I have some very basic documentation in the pipeline. will send you the pdf's in two weeks for review. The aim is to avoid the same basic questions on the forum. Lets see if it works ...
Best Regards
Jaswi
jaswi is offline   Reply With Quote
Old   July 7, 2008, 04:31
Default Hi Jaswi Please distribute
  #64
ngj
Hi Jaswi
Please distribute it, as it would be beneficial to all to have such a document.
- Niels
Old   July 7, 2008, 04:54
Default Hi Jaswi! Wouldn't http://o
  #65
Assistant Moderator
Bernhard Gschaider
Hi Jaswi!
Wouldn't http://openfoamwiki.net/index.php/Main_FAQ be an appropriate place for that kind of stuff? I know that not much has been added there in the last time, but you could change that ...
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   July 7, 2008, 11:34
Default Dear Bernhard and Niels The
  #66
The purpose of making such documentation is distribution only but it needs some peer review as it is very basic and mostly consolidates the information taken from the forum.
I just need some time (after 16th July + 1 week) to refine it.
With Best Regards
Jaswi
Old   July 7, 2008, 12:22
Default Thanks Jaswi. I'll be happy to
  #67
Alberto Passalacqua
Thanks Jaswi. I'll be happy to read it :-)
Regards,
A.
Alberto Passalacqua
Old   July 7, 2008, 13:21
Default Hi Jaswi What is not very c
  #68
ngj
Hi Jaswi
What is not very clear from my post is that I would like to read the document and give feed-back.
Best regards,
Niels
Old   July 8, 2008, 03:04
Default Hi Niels That would be grea
  #69
Hi Niels
That would be great.
Will send it over to you once I have the initial draft ready.
Best Regards
Jaswi
Old   July 18, 2008, 06:49
Default Hi everyone: I tried the ea
  #70
feng wang
fw407 is on a distinguished road
Hi everyone:
I tried the easy way of compiling OF-1.4.1-dev, but run into problems when compiling src, the errors are something like:
lex.yy.cc:6502: error: 'yy_buffer_stack_max' was not declared in this scope
lex.yy.cc:6503: error: 'yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:6507: error: 'yy_buffer_stack_top' was not declared in this scope
lex.yy.cc:6507: error: 'yy_buffer_stack_max' was not declared in this scope
lex.yy.cc:6513: error: 'yy_buffer_stack' was not declared in this scope
lex.yy.cc:6516: warning: use of old-style cast
lex.yy.cc: In member function 'void yyFlexLexer::yy_push_state(int)':
lex.yy.cc:6534: warning: use of old-style cast
lex.yy.cc:6537: warning: use of old-style cast
/usr/bin/ld: cannot find -lfiniteVolume
collect2: ld returned 1 exit status
Xstream/Xstream.C:155: error: 'ButtonPressMask' was not declared in this scope
Xstream/Xstream.C:155: error: 'KeyPressMask' was not declared in this scope
Xstream/Xstream.C:155: error: 'ExposureMask' was not declared in this scope
Xstream/Xstream.C:155: error: 'StructureNotifyMask' was not declared in this scope
I read some threads related to my problem, but haven't got a solution how to solve it, Could anyone give me some ideas?
(BTW: OS: ubuntu 7.10; gcc:4.2.1; flex: 2.5.33
Kind regards
feng
fw407 is offline   Reply With Quote
Old   July 18, 2008, 10:55
Default Hi feng, the procedure work
  #71
Alberto Passalacqua
Hi feng,
the procedure worked on openSUSE 11.0 (gcc 4.2.1 packaged by OpenCFD, flex 2.5.35).
Regards,
A.
Alberto Passalacqua
Old   July 18, 2008, 13:47
Default Hi Alberto & anyone, Thanks
  #72
feng wang
Thanks for reply. I think I've made a progress in solving the problem related to zlib, but I am now still struggling with flex,
Here is what I have in OpenFOAM-1.4.1-dev/wmake/rules/General/flex++
.SUFFIXES: .L
#Ltoo = foamFlex++ -f $$SOURCE ; mv lex.yy.cc $*.C ; $(CC) $(c++FLAGS) -c $*.C -o $@
Ltoo = flex++ -f $$SOURCE ; mv lex.yy.cc $*.C ; $(CC) $(c++FLAGS) -c $*.C -o $@
.L.dep:
$(MAKE_DEP)
Could anyone give me some help?
Kind regards
feng
Old   July 18, 2008, 14:02
Default Hi Feng ! I'm on ubuntu 8.0
  #73
Mathieu Olivier
mathieu is on a distinguished road
Hi Feng !
I'm on ubuntu 8.04 and I use Flex 2.5.4 (old flex in the synaptic package manager) and the compilation is ok.
Mathieu
mathieu is offline   Reply With Quote
Old   July 18, 2008, 15:23
Default Hi Mathieu ! Thanks for you
  #74
feng wang
Hi Mathieu !
Thanks for your help!
I tried your method, but it doesn't work, but I find way around it and make it work.
I noticed in my error list that there is something like "c++ linkage" and I get some idea from this post:
http://www.cfd-online.com/OpenFOAM_D...es/1/7503.html
so I replace:
"int yywrap()"
with
"extern "C" int yywrap()"
which is located at $WM_PROJECT_DIR/src/triSurface/triSurface/interfaces/STL/readSTLASCII.L
then most of the libraries in the "src" is compiled, except some libraries related to combustion and something else. as my project is about f-s, I tried icoFsiFoam and the stress solvers, they are all compiled correctly, anyway, OF-1.4.1-dev is working for me.
I think the uncompiled libraries can also be solved with the same method as the compiler also complains about flex-related issues.
kind regards
feng
Old   July 25, 2008, 16:37
Default Hi All I have just download
  #75
ngj
Hi All
I have just downloaded 1.4.1-dev tonight, and the finiteArea module is missing. Does anyone know if it has been redrawn or anything?
If not, when will it become available again.
Thanks,
Niels
Old   July 25, 2008, 17:16
Default Hi I am terrible sorry for
  #76
ngj
Hi
I am terrible sorry for having posted this ... turns out that I had stepped into the wrong directory and compiled the 'not-dev' version.
Time for bed.
Thanks,
Niels
Old   November 14, 2008, 21:51
Default I had my fluctuation with inst
  #77
Peter Lian
peter73 is on a distinguished road
I had my fluctuation with installation. I spent almost a whole week from 8:00am to 10:00pm and finally I got it right.
Now I have to deal with the solvers. As a beginner I need to search the internet for days for answers. SOmetimes I get it and sometimes I do not. The tutorial document is very brief and spends a large portion to introduce the grid generation. It does not cover how to code a program. It lacks the material to introduce the overall structure of this big code.
For long time users, it may be easier. I have my own in-house code. I know where to change and how to change it. But for my students it takes two years to understand the code.
Lots of users are students and they work on a project for a short time of period. The code will continue to grow, and someday, it will become so hard for a beginner to grasp and add new components (that is the purpose of a research code). They may just switch to Fluent (with a few thousand for 10 licenses, fluent is not that expensive)
I contacted the supporting group. I concern about the total number of hours (50 hours). Well, if I want to implement a new solver, I really do not know how many hours will they spend.
I agree they should get paid for their work. There could be a better way to do that.
Peter
peter73 is offline   Reply With Quote
Which version is current development line for 15 dkingsley OpenFOAM Installation 20 January 22, 2009 02:49
Which version is current development line for 15 dkingsley OpenFOAM Installation 0 January 12, 2009 08:18
Development version download guillaume OpenFOAM Installation 30 October 15, 2008 00:59
Install development version on Ubuntu hsieh OpenFOAM Installation 9 December 31, 2007 08:18
Modifying motionU in the development version philippose OpenFOAM Running, Solving & CFD 8 February 1, 2007 15:25
