OpenFOAM on cluster
Old   October 17, 2008, 07:50
Default Hi.. I'm relatively new to
Mark Herskind
markh83 is on a distinguished road
Hi..
I'm relatively new to using OpenFOAM, especially using the cluster that has been put at my disposal.. It's a rather small cluster, consisting of 5 nodes with 2 processors each.. I've read in the user manual about decomposing the domain, and i have done so, using decomposePar, and this dict-file:
// Mesh decomposition control dictionary
FoamFile
version 0.5;
format ascii;
root "ROOT";
case "CASE";
instance "system";
local "";
class dictionary;
object decompositionDict;
numberOfSubdomains 4;
//method simple;
method hierarchical;
//method metis;
//method manual;
simpleCoeffs
n (2 2 1);
delta 0.001;
hierarchicalCoeffs
n (2 2 1);
delta 0.001;
order xyz;
manualCoeffs
dataFile "decompositionData";
Thereafter i have made a hostfile (called 'machines'), listing the two nodes I would like to test on:
i14cluster-21 cpu=2
i14cluster-22 cpu=2
I've copied the case and the hostfile to the cluster-master, and via ssh I log into it.. From there do a mpirun like this:
mpirun --hostfile machines -np 4 turbFoam-vt . mesh2 -parallel
(I've edited the turbfoam for variable timesteps, and renamed it, but that part works smoothly)
But when I do this, I get an error:
[tepe3-1@i14cluster Cases]$ mpirun --hostfile machines -np 4 turbFoam_vt . mesh2
-parallel
tepe3-1@i14cluster-21's password: tepe3-1@i14cluster-22's password:
Could not chdir to home directory /home/tepe3-1: No such file or directory
bash: orted: command not found
[i14cluster:31446] [0,0,0] ORTE_ERROR_LOG: Timeout in file base/pls_base_orted_c
mds.c at line 275
[i14cluster:31446] [0,0,0] ORTE_ERROR_LOG: Timeout in file pls_rsh_module.c at l
ine 1164
[i14cluster:31446] [0,0,0] ORTE_ERROR_LOG: Timeout in file errmgr_hnp.c at line
90
[i14cluster:31446] ERROR: A daemon on node i14cluster-21 failed to start as expe
cted.
[i14cluster:31446] ERROR: There may be more information available from
[i14cluster:31446] ERROR: the remote shell (see above).
[i14cluster:31446] ERROR: The daemon exited unexpectedly with status 127.
mds.c at line 188
ine 1196
mpirun was unable to cleanly terminate the daemons for this job. Returned value
Timeout instead of ORTE_SUCCESS.
Can anybody give me a hint of what I'm doing wrong?
markh83 is offline   Reply With Quote
Old   October 17, 2008, 19:09
Default Hi Mark, 1. try parallel ru
Jens Klostermann
jens_klostermann is on a distinguished road
Hi Mark,
1. try parallel running on ONE node! if it works try.
2. check if you have set up passwordless ssh to the nodes
3. check if your home with your case is available on every node (usually shared raid e.g. through NFS)
4. check if compiled and or linked your mpi-lib, e.g. openmpi-1.2.6 or vendors mpi
Jens
jens_klostermann is offline   Reply With Quote
Cluster test with openfoam clo OpenFOAM Running, Solving & CFD 7 February 22, 2009 23:44
How to run Openfoam in a cluster after I install it xiuying OpenFOAM Installation 5 May 5, 2008 12:54
OpenFOAM users in Munich OpenFOAM benutzer in M%c3%bcnchen jaswi OpenFOAM 0 August 3, 2007 13:11
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 08:54
OpenFOAM in a Linux Cluster gedanken OpenFOAM Installation 1 August 25, 2005 13:32
