'GLIBC_2.3.4' not found
Old   April 2, 2009, 01:57
Default 'GLIBC_2.3.4' not found
Peter Huang
peterhuang is on a distinguished road
Hi all,
Just downloaded OpenFOAM-1.5 and installed the package by following the README up to Step 5. When I ran foamInstallationTest it showed a few "no" here and there but did not complain about any error in particular. I then copied the tutorial files as instructed in Step 6 and here comes the problem: when I type in blockMesh I got the following error message:
blockMesh: /lib64/tls/libc.so.6: version `GLIBC_2.3.4' not found (required by /home/peterh/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so)
I am new to Linux so I could have made some mistake somewhere, the trouble is I'm not proficient enough to pin point the error. Is anyone having similar problem? Any help is appreciated, thank you in advance!
Additional Info: I'm running Red Hat Enterprise Linux so I've downloaded and installed the 64-bit packages. I've also attached the result from foamInstallationTest below:
Checking basic setup...
Shell: bash
Host: cfddeepthought.vipac.com.au
OS: Linux version 2.4.21-37.ELsmp
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/peterh/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/peterh/OpenFOAM/peterh-1.5 yes no
$WM_THIRD_PARTY_DIR /home/peterh/OpenFOAM/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/peterh/OpenFOAM/OpenFOAM-1.5 yes yes yes
$FOAM_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_USER_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes no
$WM_DIR /home/peterh/OpenFOAM/OpenFOAM-1.5/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OAM/OpenFOAM-1.5/lib/linux64GccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...nFOAM/peterh-1.5/lib/linux64GccDPOpt yes yes no
$MPI_ARCH_PATH ...nmpi-1.2.6/platforms/linux64GccDPOpt yes yes yes
Third party software
Software Version Location
gcc 4.3.1 ...penFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc
gzip 1.3.3 /usr/bin/gzip
tar 1.13.25 /bin/tar
icoFoam .../OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam
Checking networking...
Action Result Crit
...pthought.vipac.com.au Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the OpenFOAM enviroment.
Base configuration ok.
Critical systems ok.
done.
peterhuang is offline   Reply With Quote
Old   April 2, 2009, 10:40
lin
Hua Zen
lin is on a distinguished road
I guess you should compile from source.
lin is offline   Reply With Quote
Old   April 2, 2009, 19:44
Peter Huang
Thanks for the reply Lin.
Sorry for asking this trivial question (I've only started using Linux since 4 days ago): how do I compile from the source code?
I'm doing some tutorials to get myself up to speed with Linux, but I'm still very green at the moment and I have no idea how to compile from the source. I would really appreciate a step by step instruction on how to do this if it's available.
Old   April 8, 2009, 20:23
Ahmed
Ahmed is on a distinguished road
Read the error message. A library is missing, so use the package manager on your system and install it.
Ahmed is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
