May 22, 2008, 11:05 |
Hi People,
I am a newb to
Lawrence
Rep Power: 17 |
Hi People,
I am a newb to linux/openfoam and hope can get some help here. I just installed puppy 4 as the linux and installed OpenFOAM 1.4.1 according to the online guideline. However, when i typed FoamX, it says error "nsd"command not found with the FoamXHB(?) file at line 130, when i go to open and read the file, it s basically a line started with "nsd" command. is there any suggestion to fix this? also, i tried to follow the online step by step guide to run the dailyPitz but when it comes to blockMesh.cavity, it says command not found/no such command. I understand that it might be better to use command rather than FoamX but I would really like to start with FoamX and at least go through the tutorials. any help/suggestion is welcomed. cheers |
May 22, 2008, 12:00 |
Hi Lawrence, and welcome.
Fir
Dragos
Rep Power: 20 |
First try to run icoFoam, and type: icoFoam If it prints "command not found" than it means you did not configure the environment. Do you have in your ~/.bashrc a line saying: . ~/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc ? Dragos |
May 22, 2008, 12:28 |
Hi Dragos,
thanks for your q
Lawrence
Rep Power: 17 |
Hi Dragos,
thanks for your quick reply. Sorry as i am really a newbie here, do u mean i first go into # cd ~/OpenFoam/OpenFoam-1.4.1/tutorials then type # icoFoam if so, it says command not found and as you said, i did not configure the environment.( can u provide some help on how to configure then?) for the second part, do u mean i should just #~/.bashrc and see what it says?nothing come out for the above command at the moment please bear with mi with great patience, truly appreciated. Lawrence |
May 22, 2008, 14:01 |
hi, this is what i did,
# c
Lawrence
Rep Power: 17 |
# chmod -v 555 foamSystemCheck then #["export PATH=$PATH:~/OpenFOAM/OpenFOAM-1.4.1/bin/"] it returned bash:[export PATH=/bin:/usr/bin:/sbin:/usr...usr/local/bin:/usr/X11R7/bin:/root/my-applicatio ns/bin:/opt/samba/bin:~/OpenFOAM/OpenFOAM-1.4.1/bin/]: No such file or directory i suspect the path is wrong? but how should i correct/change it? help pls.. Thanks Lawrence |
May 22, 2008, 14:22 |
Lawrence, could you do pwd in
Anonymous
Rep Power: 17 |
Lawrence, could you do pwd in the directory where foamSystemCheck is located? Are you running 32 or 64 bit linux?
May 23, 2008, 02:29 |
Hi Lawrence,
It seems that yo
Dragos
Rep Power: 20 |
Hi Lawrence,
It seems that you need more help, so if you want drop me an e-mail and I will try to provide you with the information. Dragos |
Display Modes | |
FoamX error | illan | OpenFOAM Installation | 1 | May 22, 2008 00:45 |
Foamx error | rengu | OpenFOAM Pre-Processing | 1 | April 24, 2008 07:04 |
Error with FoamX | skabilan | OpenFOAM Installation | 0 | March 25, 2008 17:20 |
FoamX Error | yinyajun436 | OpenFOAM Pre-Processing | 1 | November 19, 2007 12:05 |
FoamX error | derath | OpenFOAM Pre-Processing | 2 | April 25, 2007 06:51 |
