FoamX and Java Issues
Old   March 7, 2008, 04:19
Default Hi, I've installed OpenFOAM
OliH
olih is on a distinguished road
I've installed OpenFOAM 1.4.1 on Ubuntu 8.04. Tutorials work OK but I have troubles when trying to open FoamX. When I type "FoamX" at the terminal, I get the following message (headers removed):
HostBrowser running.....
Setting LANG to en_EN
Using jar /home/oheynes/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/preProcessing/FoamX /lib/FoamX.jar
Using jar /home/oheynes/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/preProcessing/FoamX /lib/jlfgr-1_0.jar
Locking assertion failure. Backtrace:
#0 /usr/lib/libxcb-xlib.so.0 [0xb37e0767]
#1 /usr/lib/libxcb-xlib.so.0(xcb_xlib_unlock+0x31) [0xb37e08b1]
#2 /usr/lib/libX11.so.6(_XReply+0xfd) [0xaa74129d]
#3 /home/oheynes/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/libawt.so(XineramaQueryS creens+0xd0) [0xaa9d47b8]
#4 /home/oheynes/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/libawt.so(xineramaInit+0 x6f) [0xaa98df4b]
#5 /home/oheynes/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/libawt.so(awt_init_Displ ay+0x1af) [0xaa98e21b]
#6 /home/oheynes/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/libawt.so(Java_sun_awt_X 11GraphicsEnvironment_initDisplay+0x1d) [0xaa98e445]
#7 [0xb389b401]
#8 [0xb3894e9b]
#9 [0xb38921c4]
#10 /home/oheynes/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/client/libjvm.so [0xb7b35454]
#11 /home/oheynes/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/client/libjvm.so [0xb7be93ad]
#12 /home/oheynes/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/client/libjvm.so [0xb7b356a6]
#13 /home/oheynes/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/client/libjvm.so [0xb7b1a74f]
#14 /home/oheynes/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/client/libjvm.so [0xb7b1ee7c]
#15 /home/oheynes/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/client/libjvm.so [0xb7b199ab]
#16 /home/oheynes/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/client/libjvm.so [0xb7b1f18f]
#17 /home/oheynes/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/client/libjvm.so [0xb7b95e78]
#18 /home/oheynes/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/client/libjvm.so(JVM_Fin dClassFromClassLoader+0x208) [0xb7b85140]
#19 /home/oheynes/OpenFOAM/linux/j2sdk1.4.2_05/jre/lib/i386/libjava.so(Java_java_lan g_Class_forName0+0x182) [0xb78fc97e]
java: xcb_xlib.c:82: xcb_xlib_unlock: Assertion `c->xlib.lock' failed.
Aborted (core dumped)
Killed
runFoamXHB : cleanup
runFoamXHB: Killing name server nsd(pid 6273).
kill: 133: No such process
I've checked and the files it is looking for are correct and in the correct directories (no case sensitivity issues).
Can anyone help me? I'm a newbie when it comes to Linux I'm afraid - just starting out.
Oli
olih is offline   Reply With Quote
Old   March 7, 2008, 05:14
Default Hi Oli, The problem has been
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Oli,
The problem has been discussed already on other threads. See this answer for instance:
xlib.lock
Dragos
dmoroian is offline   Reply With Quote
Old   March 11, 2008, 21:52
Default My FoamX don't run. The messag
Délio Barroso de Souza
delio141 is on a distinguished road
My FoamX don't run. The message appear to me:
Cannot find JDK at /home/delio/OpenFOAM/linux64/j2sdk1.4.2_05. Please set JAVA_PATH to the
JDK installation directory.
I don't know where is it, and I don' know how to configurate it.
I need a help about this
Tanks
delio141 is offline   Reply With Quote
Old   March 12, 2008, 14:26
Default What does the following comman
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
What does the following command tell you:
ls -la /home/delio/OpenFOAM/linux64/
msrinath80 is offline   Reply With Quote
Old   March 30, 2008, 16:35
Default Hi all! I am new Linux+Open
Iori
iatsouk is on a distinguished road
Hi all!
I am new Linux+OpenFoam user.
I have met the same problem:
~/OpenFOAM/OpenFOAM-1.4.1/bin> FoamX
Cannot find JDK at /usr/java/jdk1.4. Please set JAVA_PATH to the
Iori@linux:/usr/java> ls -la
total 12
drwxr-xr-x 3 root root 4096 Mar 30 23:47 .
drwxr-xr-x 13 root root 4096 Mar 30 21:37 ..
drwxrwxr-x 9 root root 4096 Mar 30 23:47 j2sdk1.4.2_17
How I can set this JAVA_PATH?
iatsouk is offline   Reply With Quote
Old   March 30, 2008, 17:22
Default You look at the download page
Graeme Cottrell
platopus is on a distinguished road
http://www.opencfd.co.uk/openfoam/linux.html#linux
and right down the bottom it tells you which file you have to modify.
Regards.
platopus is offline   Reply With Quote
FoamX Java problem kris OpenFOAM Installation 17 February 6, 2012 17:24
Java error while starting FoamX erydj OpenFOAM Pre-Processing 2 May 4, 2007 08:53
FoamX Issues tger003 OpenFOAM Pre-Processing 0 January 18, 2007 14:50
FoamX problems with Java and Locale setting AMD64 geimerma OpenFOAM Installation 5 July 7, 2006 16:21
Java error while starting FoamX cfdengineering OpenFOAM Pre-Processing 16 June 28, 2006 20:02
