Installing from source to a different location
Old   October 24, 2007, 19:12
Default Hi all, Perhaps you can hel
jmk1k
Hi all,
Perhaps you can help me out as I seem kind of stuck in getting OpenFOAM installed in the location I want it to.
As we use a cluster, our installation is supposed to be installed on a shared NFS environment and for tuning reasons we want to build it from scratch.
The compiling and linking seems to go fine but installing OpenFOAM in a different directory other than $WM_PROJECT_DIR causes everything to fail during the build process. Setting the env. variable WM_PROJECT_INST_DIR is set to the directory I want OpenFOAM to be installed (totally separate from the source environment) but this gets totally ignored.
Does anybody know what I'm doing wrong? (it would seem rather obvious to just set the WM_PROJECT_INST_DIR and have the build process automagically install it there but it seems hellbent on installing in WM_PROJECT_DIR)
Regards,
Jeroen
Installing as root in opt bastil OpenFOAM Installation 8 October 22, 2008 02:54
installing cfx 5.6 bagi CFX 1 December 27, 2005 15:13
Installing 12 after removing 11 maka OpenFOAM Installation 5 August 26, 2005 17:17
UDF: source term dependent on location Vladimir Krejci FLUENT 0 April 2, 2003 08:38
Installing Compiled UDF HARI SARYONO FLUENT 0 November 24, 2001 01:48
