Getting FoamX to work
Old   March 5, 2007, 02:55
Default Hello, I have installed OpenFO
Shaun Darmody
shaun is on a distinguished road
Hello, I have installed OpenFOAM-1.3 on my Ubuntu 6.06 LTS installation. I am using a Dell 490 box with intel XEON 64bit CPU's.
A little while ago I posted on here issues with getting FoamX to run on my Ubuntu installation and noted that the libelf files where already installed at /usr/lib.
When attempting to run FoamX i still get the following error.
Starting NameServer with inet:PhantomWorks:1234 ...
nsd: error while loading shared libraries: libelf.so.0: cannot open shared object file: No such file or directory
Now, I have searched through all the posts in this Installation folder on the discussion board and also looked at a number of posts on the FoamX folder as well. After this search, I attempted to disable SELinux but found it not to be installed. I also tried looking to see if SSH was installed and when typing which ssh i get /usr/bin/ssh.
I then type at my prompt and receive the following error.
lads@PhantomWorks:~$ ssh PhantomWorks
ssh: connect to host PhantomWorks port 22: Connection refused
I have then checked the firewall here in ubuntu (iptables):
lads@PhantomWorks:~$ sudo iptables -L
Password:
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Nothing is being blocked, let alone SSH. Why doesn't SSH work then? Why do I need SSH to work when I only want to run on a stand-alone box?
Now, I have run the two commands:
blockMesh . cavity
icoFoam . cavity
and had no problem what so ever in getting the solver to work. So as far as I can see I have no problem with my OpenFOAM-1.3 installation. I just can't for the life of me get this FoamX software to find the libelf.so.0 even though it is exactly where everyone here says it should be!!
I have installed the 32bit version of OpenFOAM-1.3. Initially when I first ran foamInstallationTest i had to set the directory path of the gcc complier location to
/home/lads/OpenFOAM/linux/gcc-4.1.0-64/bin/gc
for it to find my 32bit binary I downloaded with the OpenFoam software package. Is this strange?
The current foamInstallationtest gives the following output:
Executing foamInstallationTest:
Checking basic setup...
Shell: bash
Host: PhantomWorks
OS: Linux version 2.6.15-23-amd64-generic
User: lads
User_config: /home/lads/.bashrc
Foam_config: /home/lads/.OpenFOAM-1.3/bashrc sourced correctly.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/lads/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/lads/OpenFOAM/lads-1.3 yes no
$FOAM_JOB_DIR /home/lads/OpenFOAM/jobControl no yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/lads/OpenFOAM/OpenFOAM-1.3 yes yes yes
$FOAM_USER_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes yes no
$FOAM_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes yes yes
$WM_DIR /home/lads/OpenFOAM/OpenFOAM-1.3/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH /home/lads/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no
$MICO_ARCH_PATH ...mico-2.3.11/platforms/linuxGcc4DPOpt yes yes yes
$LAM_ARCH_PATH ...c/lam-7.1.1/platforms/linuxGcc4DPOpt yes yes yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...FOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt yes yes yes
$FOAM_USER_LIBBIN ...OpenFOAM/lads-1.3/lib/linuxGcc4DPOpt yes yes no
Software versions
Software Version Location
gcc 4.1.0 /home/lads/OpenFOAM/linux/gcc-4.1.0-64/bin/gcc
java 1.4.2_05 /home/lads/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
gzip 1.3.5 /bin/gzip
tar 1.3.5 /bin/tar
icoFoam ...M/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/icoFoam
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_PhantomWorks Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Unsuccessful_connection_refused* yes
FATAL ERROR: No remote shell available.
Foam1.3 enviroment requires either ssh and/or rsh.
Contact your system administrator.
The system test has evoked 1 fatal error(s).
Critical systems ok.
Review the output for warning messages and consult the installation guide for trouble shooting.
Now, I am getting really frustrated with this software. I have tried everything, and am at the limit of my linux knowledge/expertise.
My group here at BOEING Australia are extremely interested in using this software and so I am now contemplating installing OpenSUSE 10.1 as no-one seems to have a problem once they download the libelf.so.0 from YaST.
Last time I posted, some gentlemen from Adelaide Uni where kind enough to reply to my post about these issues with FoamX, libelf and Ubuntu. Yet as far as I can see, they too do not use the FoamX GUI.
How can I learn OpenFoam without the GUI when all your tutes etc are using this FoamX GUI?
I am stuck.
Can anyone help?
Please.
Thanks for your time.
Regards
Shaun.D
shaun is offline   Reply With Quote
Old   March 5, 2007, 03:31
Default Hi Shaun, For me it sounds
rafal zietara
rafal is on a distinguished road
Hi Shaun,
For me it sounds like you have problems
with ssh not with OF. Can you use ssh
(not in FOAM)? read your foamInstallationtest
output carefully. you need to have either
ssh or rsh. ssh preferable because it is secure.
Second thing. You really do NOT need FoamX.
Even if you manage to install it, you will
drop it after several days of weeks(i bet).
It is limited. I dropped it after two weeks
and used it never again.
good luck,
rafal
ps third thing you in the output you can
also read that you do not have any mpi lib
set correctly(this also can say about problems
with remote shell). So far do not bother with
mpi but keep this in mind when you will need
to calculate something parallel.
parallel, but for now do not bother.
rafal is offline   Reply With Quote
Old   March 5, 2007, 03:37
Default Hi, I know nothing about Ubun
Takuya OSHIMA
7islands is on a distinguished road
I know nothing about Ubuntu but is your libelf.so.0 a 32bit binary? If I'm not wrong you need 32bit libelf.so.0 to run the 32bit nsd.
Basically it is preferable to install the 64bit version of OpenFOAM under a 64bit Linux. Since many of OpenFOAM users do so I think at least the probability of you getting any suggestion will be higher.
7islands is offline   Reply With Quote
Old   March 5, 2007, 03:44
Default i didnt actually answer you qu
rafal zietara
i didnt actually answer you questions
FoamX in only a front-end of OF in java. it works
like a server that connects to a maschine. This is
a reason why you need remote shell in FoamX and you
do not need in icoFoam.
You can learn everything without FoamX by typing
all commands in shell. if you know what you want
to do type a command in shell and output returns error and correct syntax (which you need).
(list of commands you can find at the end of User
Guide
Old   March 5, 2007, 17:03
Default Thanks to both of you gents fo
Shaun Darmody
Thanks to both of you gents for your replys. I will install the 64bit version of OpenFOAM and will ignore trying to use FoamX.
I am unsure if my libelf.so.0 is 32bit binary. I did install the amd64bit-generic version of Ubuntu.
I don't believe the MPI lib is an issue, as LAM is installed by default.
Thanks again.
Old   March 5, 2007, 23:02
Default So, Takuya, I installed the 64
Shaun Darmody
So, Takuya, I installed the 64bit version of OpenFOAM 1.3 and guess what, FoamX worked straight away.
I guess your idea about the libelf being of 64bit form instead of 32bit was correct.
Thanks
Old   March 14, 2007, 17:30
Default When I run the command, block
Toni Toney
tonitoney is on a distinguished road
When I run the command, blockMesh . cavity, I get the following error message.
blockMesh: error while loading shared libraries: libmeshTools.so: cannot open shared object file: No such file or directory.
Can someone help me with this? I just installed OpenFOAM 1.3 on AMD64 Opteron running SuSe Linux and am trying to test it.
Thanks.
tonitoney is offline   Reply With Quote
Old   March 14, 2007, 17:34
Default Toni, I would suggest you have
Shaun Darmody
Toni, I would suggest you have not installed the OpenFoam source code either properly or not at all.
Make sure your installation is correct and that you have installed in sequence the source code and binary files in the correct location.
See the readme file when you download OF 1.3
Regards
Shaun.D
Old   March 14, 2007, 19:33
Default Did you set up the environment
Hrvoje Jasak
Did you set up the environment variable WM_64 to indicate you are running a 64-bit version?
Installation from binaries shoule be pretty straightforward, based on the README file.
Hrv
Hrvoje Jasak
Old   March 23, 2007, 05:17
Default did onebody help me! i instal
hamdi
hamcer is on a distinguished road
i installed a linux Mandriva in my loptop tosciba
and i installed openfoam where i unpaked the paraview unde OpenFOAM dir not under OpenFOAM/linux/ and foaminstallationtest gives this:
Shell: bash
Host: localhost
OS: Linux version 2.6.17-5mdv
User: nacer
User_config: /home/nacer/.bashrc
Foam_config: /home/nacer/.OpenFOAM-1.3/bashrc sourced correctly.
$WM_PROJECT_INST_DIR /home/nacer/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/nacer/OpenFOAM/nacer-1.3 yes no
$FOAM_JOB_DIR /home/nacer/OpenFOAM/jobControl no yes
$WM_PROJECT_DIR /home/nacer/OpenFOAM/OpenFOAM-1.3 yes yes yes
$WM_DIR /home/nacer/OpenFOAM/OpenFOAM-1.3/wmake yes yes yes
$JAVA_PATH /home/nacer/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no
$FOAM_USER_LIBBIN ...penFOAM/nacer-1.3/lib/linuxGcc4DPOpt yes yes no
Software versions
gcc 4.1.0 /home/nacer/OpenFOAM/linux/gcc-4.1.0/bin/gcc
java 1.4.2_05 /home/nacer/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
gzip 1.3.5 /usr/bin/gzip
tar 1.3.5 /bin/tar
Action Result Crit
Pinging_localhost Successful yes
Test_rsh: No_telnet_running:_cannot_check* yes
Test_ssh: No_telnet_running:_cannot_check* yes
and when i execute FoamX it gives me this:
stareting menserver with inlet :localhost: 1234
nsd : error while loading shared libraries : libelf.so.0: cannot open object file: no such file or directory
hamcer_n@hotmail.com
hamcer is offline   Reply With Quote
Old   March 23, 2007, 05:28
Default Hi hamdi! Havn't used FoamX
  #11
Assistant Moderator
Bernhard Gschaider
Hi hamdi!
Havn't used FoamX in a long time, so I can only guess. The problem might be that nsd expects to find a libelf.so.0, but there is none on your system. Check with
ls /usr/lib/libelf*
which version are on your system. Then you might cheat with a symbolic link:
ln -s /usr/lib/libelf.so.0.97 /usr/lib/libelf.so.0
(use a version that exists on your system)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 23, 2007, 08:09
Default thank you Bernhard Gschaider f
  #12
hamdi
thank you Bernhard Gschaider for your help;
i do what you sugget :
when i type :ls /usr/lib/libelf*
it gives:
/usr/lib/libelf-0.120.so* (green color) /usr/lib/libelf.so.1 (blue color)
and when i type:
it gives:
ln: creation d'un lien symbolique /usr/lib/libelf.so.0 vers /usr/lib/libelf.so.0.97 : permission non accordée
(linux is in french version)
hamdi.
Old   March 23, 2007, 08:55
Default You have to be root in order t
  #13
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
You have to be root in order to create that link.
Dragos
dmoroian is offline   Reply With Quote
About FoamX ivanyao OpenFOAM Installation 2 September 21, 2008 21:24
Problem about FoamX williamscn OpenFOAM Installation 8 September 17, 2007 23:18
FoamX problem richardhsieh OpenFOAM Installation 4 September 17, 2007 22:41
FoamX ianz8802 OpenFOAM Installation 2 March 8, 2007 23:45
Run FoamX ghazi OpenFOAM Pre-Processing 7 July 9, 2006 14:48
