How to install binary pack in Debian 31 Linux |
February 6, 2007, 12:59 |
Hi All,
I have download all
Navaladi ( navaladi@gmail.com)
Rep Power: 17 |
Hi All,
I have download all the files. I want to use Binary Pack,It has following files. navaladi@debian:~/OpenFOAM/binary/OpenFOAM-1.3$ ls -l total 16 drwxr-xr-x 3 navaladi navaladi 4096 2007-02-04 12:30 applications drwxr-xr-x 3 navaladi navaladi 4096 2007-02-04 12:30 lib drwxr-xr-x 4 navaladi navaladi 4096 2007-02-04 12:30 src drwxr-xr-x 3 navaladi navaladi 4096 2007-02-04 12:30 wmake navaladi@debian:~/OpenFOAM/binary/OpenFOAM-1.3$ I have found no install/README file, and no install script. Can anyone tell me how to install it. |
February 7, 2007, 05:32 |
Hi Navaladi,
You will need b
Rasmus Hemph
Rep Power: 17 |
Hi Navaladi,
You will need both the binary pack *and* the source pack to install OpenFOAM. The installation README file comes in the source package I believe. The preferred location of OpenFoam-1.3 is in the ~/OpenFOAM -directory (i.e. no 'binary' folder is needed). Take a look at http://www.opencfd.co.uk/openfoam/linux.html for further instrucions. Good luck! //Rasmus |
February 7, 2007, 13:33 |
hi Rasmus, Thanks for reply.
Rep Power: 17 |
Then, should i have to compile it manually?What is the need for Binary Pack developed for Linux.I can build it without binary pack. I searched entire forum, i didn't get any clue for that.I have found pre-compiled binaries under applications/ folder ( with FoamX). Thanks |
February 8, 2007, 05:01 |
Hi again,
The binary pack con
Rasmus Hemph
Rep Power: 17 |
Hi again,
The binary pack contains compiled libraries and executables for the linux or AMD-64 platform. They are not required for running OpenFOAM (you could compile everything yourself using the source package), but save time and effort for us linux-users on intel and AMD systems. If you are a new user on one of those systems, I recommend you use the binary pack. The source pack contains essential applications and scripts as well as the complete source code and documentation. It must be installed in order to run OpenFOAM. //Rasmus |
February 8, 2007, 08:18 |
Yeah Thanks Rasmus, I understa
Rep Power: 17 |
Yeah Thanks Rasmus, I understand.I ll compile it myself.
Thanks |
LibPV3FoamReader_SMso and FoamReaderso missing in binary pack | sam | OpenFOAM Installation | 2 | October 30, 2008 08:08 |
Can I use the binary files for ia64 and x86_64 CPU in Linux OS | mamaly60 | OpenFOAM Installation | 4 | October 24, 2007 22:20 |
Can Starcd for linux run in Linux Debian? help | deisler | Siemens | 1 | February 28, 2007 04:27 |
Fluent 6.2 on debian linux | Chris | FLUENT | 3 | June 2, 2005 05:21 |
Fluent on Suse,Debian Linux? | Angus MacLeod | FLUENT | 3 | September 27, 2000 11:48 |
